Correct .mpls for Criminal
- Contact:
Re: Correct .mpls for Criminal
By any chance, can you try the latest version (1.10.1) and see if it marks the correct title?
It doesn't mark any title or give any indication as to what the main movie or correct title is. 559.mpls is correct for me but it isn't listed in any special way vs. the other titles.mike admin wrote:By any chance, can you try the latest version (1.10.1) and see if it marks the correct title?
1.10.1 did mark the correct title for me
Are you working directly off the disc, off an encrypted backup, or off a decrypted backup? BD-Java decryption doesn't work from a decrypted backup as of yet, but direct off the disc OR from an encrypted backup should be ok.unab0mb wrote: It doesn't mark any title or give any indication as to what the main movie or correct title is.
Hi Mike,mike admin wrote:By any chance, can you try the latest version (1.10.1) and see if it marks the correct title?
1.10.1 isn't marking the correct title for my European disc.
I was working directly off of the original disc. Regarding this BD-Java decryption, is Java necessary to be installed on my PC? I don't install Java due to it being a slow and unsecure pile of crap. MakeMKV makes no indication that this is a required component, or provide any information as to what it does, if it is missing, etc.Yugatha wrote:Are you working directly off the disc, off an encrypted backup, or off a decrypted backup? BD-Java decryption doesn't work from a decrypted backup as of yet, but direct off the disc OR from an encrypted backup should be ok.unab0mb wrote: It doesn't mark any title or give any indication as to what the main movie or correct title is.
Java is a requirement for decoding the Java-based file selection, but MakeMKV will function without it.
I'm with you as far as allowing Java on a computer. If there was a secure, compatible run time package out there, maybe. But anything that is "secure" isn't "compatible".
Edited to hide my stupidity. Although Java was installed, I was unaware, and did not notice that the main feature is selected for me automatically now by MakeMKV.
My apologies.
My apologies.
- Contact:
It should have told you for this specific disc. Can you please post the log file?unab0mb wrote:MakeMKV makes no indication that this is a required component, or provide any information as to what it does, if it is missing, etc.
- Contact:
Please do this - http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330Krobar wrote:1.10.1 isn't marking the correct title for my European disc.
Does anyone know the correct playlist for Redbox? Some say 559 but my disc doesn't contain a 559 playlist. It skips from 548 to 565.
My mistake. I'm used to finding the mpls file in sequence. 00559.mpls for some reason was near the top of the playlists as title #3 for this disc.
Anyone ever get playlist 950 for this?
For which version?jriker1 wrote:Anyone ever get playlist 950 for this?
U.S. Retail
Title information
Source file name: 00950.mpls
Duration: 1:53:34
Chapters count: 16
Segment count: 20
Segment map: 508,502,517,518,512,520,515,506,509,501,504,510,505,519,513,511,516,514,507,503
File name: Criminal_t282.mkv
Title information
Duration: 1:53:34
Chapters count: 16
Segment count: 20
