Can't find .MakeMKV directory
adave
#1 Post by adave » Sat May 01, 2010 1:21 am
I tried searching my Ubuntu minimal install for the .MakeMKV installation and can't seem to find it. MakeMKV works and I located makemkv and makemkvcon files in the /usr/bin directory, but no .MakeMKV folder. Can anyone tell me where to find it? Thanks.
Btw, I made sure to search hidden folders/files as well. Tried to find it through terminal with locate function but no luck.
skittle
Re: Can't find .MakeMKV directory
#2 Post by skittle » Sat May 01, 2010 3:05 am
huh? there is no /.makemkv/
you can make one your self of course... and point makemkv to it in the preferences.
adave
#3 Post by adave » Sat May 01, 2010 4:08 am
Oh ok. Then where is the settings.conf file for MakeMKV where I would enter the new beta key? i was referencing this post from a user earlier.
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=1318
skittle
#4 Post by skittle » Sat May 01, 2010 4:04 pm
You can create one your self
/home/<user>/.MakeMKV/settings.conf
or if you 'register' in the gui, it will create the file and folder for you.
ggking7
#5 Post by ggking7 » Sat May 01, 2010 4:57 pm
Has anyone been able to get this to work? My evaluation period is expired and putting the new BETA key in settings.conf doesn't seem to make any difference. Do I need anything in setting.conf besides the appKey? It's the only line in my file.
skittle
#6 Post by skittle » Sat May 01, 2010 5:05 pm
 cat settings.conf
app_Key = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
ggking7
#7 Post by ggking7 » Sat May 01, 2010 5:32 pm
Ouch. Completely my fault. I forgot the underscore in app_Key. Sorry to waste everyone's time.
adave
#8 Post by adave » Sat May 01, 2010 7:25 pm
@skittles. Ah ok. Thanks for that. I'm running Ubuntu minimal so no GUI. I'll create the the .MakeMKV directory manually and put the key into settings.conf.
Jugin
#9 Post by Jugin » Thu Sep 01, 2011 10:39 am
Hello)) What will the pricing scheme look like when MakeMKV is no longer beta? Will MakeMKV work properly for blu-ray playback within Fedora?
