Guardians Of The Galaxy
OrangeLoon
Post by OrangeLoon » Tue Aug 16, 2016 12:41 pm
Error Log before I canceled the rip:
MakeMKV v1.10.1 win(x86-release) started
File 00800.mpls was added as title #0
File 00200.mpls was added as title #1
File 00201.mpls was added as title #2
File 00020.mpls was added as title #3
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.mpls was added as title #4
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00029.m2ts was added as title #5
File 00030.m2ts was added as title #6
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00302.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00303.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00333.m2ts was added as title #7
Title #00334.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00339.m2ts was added as title #8
Title #00342.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00343.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00344.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00345.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00346.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00347.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 9 titles into directory O:/Video/MARVEL'S_GUARDIANS_OF_THE_GALAXY_-_BLU-RAY
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '869332992'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '869332992'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '869335040'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '869335040'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '869922816'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '869922816'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '869924864'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1743912960'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '1743912960'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1743912960'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1744041984'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1746923520'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1746923520'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1747906560'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1748170752'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1748828160'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1749350400'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1749350400'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1749352448'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '1749352448'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1749479424'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1749940224'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1750462464'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '1750462464'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1750597632'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1750597632'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom1' at offset '1750597632'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1750597632'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1751052288'
Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1751476224'
Failed to save title 0 to file O:/Video/MARVEL'S_GUARDIANS_OF_THE_GALAXY_-_BLU-RAY/MARVEL'S_GUARDIANS_OF_THE_GALAXY_-_BLU-RAY_t00.mkv
0 titles saved, 9 failed
Re: Guardians Of The Galaxy
Post by Woodstock » Tue Aug 16, 2016 2:09 pm
The errors indicate that the drive had problems reading the disk.
Given the offset into the file and the type of errors, I would say it is more likely to be a power problem on a USB-powered drive than a dirty disk.
USB-powered drives have to be plugged into a fully-powered port (like directly into the computer, or on a hub with a separate power supply) to run at full speed, and often will simply go "off line" in mid-rip, if the ripping speed gets too high. And MakeMKV can definitely get to the top end of most drives out there.
But start with wiping the disk down with a damp, soft cotton cloth. New DVDs and BDs can have a hazy layer from the chemicals in the packaging equipment, yet still look "clean". I've had a number of disks like this since the first of the year.
OrangeLoon
Post by OrangeLoon » Tue Aug 16, 2016 2:24 pm
The drive is not hooked up via USB. It is a SATA internal and powered off the power supply. I have the same (similar) problem with another disc (see my "Captain America The First Avenger Errors" posting) and come to find out both are from the same source off eBay. I am starting to think the disc are bad (refurbished).
