UPDATE: New BD+ as found in avatar
crowfax
Re: UPDATE: New BD+ as found in avatar
Post by crowfax » Fri Apr 30, 2010 5:44 pm
Ohhh.. ok I get get. Sorry, not enough coffee in me this morning.
Thanks for the info!
setarip_old
Post by setarip_old » Fri Apr 30, 2010 5:54 pm
@crowfax
You're quite welcome ;>}
alehel
Post by alehel » Fri Apr 30, 2010 8:20 pm
Maybe I've just misunderstood. If that is the case, I apologize in advance.
Does this mean that avatar.sqv will eventuelly become part of the allcombo.sqv file, or will we always have to have it as a seperate file?
setarip_old
Post by setarip_old » Fri Apr 30, 2010 8:41 pm
@alehel
I suppose time will tell - depending on what and when Rovi (formerly Macrovision), on behalf of the studios, comes up with in the way of a new iteration of BD+ and/or other protections.
Based on what they did regarding "Avatar", I believe Rovi is attempting to "drown" the authors/publishers/software engineers of MakeMKV, DVDFab, and AnyDVDHD with so many different variations that timeliness and thoroughness (solutions that work for all locations) in providing solutions becomes a problem.
Again, I believe time will tell...
skittle
Post by skittle » Fri Apr 30, 2010 9:34 pm
Just wanted to say thanks, watching my copy of avatar streaming from makemkv to my NMT :)
Post by mike admin » Sat May 01, 2010 7:20 am
alehel wrote:Maybe I've just misunderstood. If that is the case, I apologize in advance.
It is now. The updated allcombo.svq and avatar.svq are the same file.
dtblair
Post by dtblair » Sat May 01, 2010 2:26 pm
I'm a little confused. Is the svq file "required" for MakeMKV? I've never had to reference the allcombo.svq since beginning using MakeMKV. Perhaps this is not required for english Blu-rays?
dmwilson1990
Post by dmwilson1990 » Sat May 01, 2010 6:36 pm
Hmm...not quite sure what I'm doing wrong...I've loaded the appropriate SVQ files and pointed MakeMKV to their directory. However, the application does not appear to be loading the SVQ files for some reason. I am reading a backup made using MakeMKV 1.5.4 but that shouldn't make any difference...should it? Any help would be greatly appreciated. Thanks!
MakeMKV v1.5.5 beta darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
Optical drive "BD-ROM Optiarc BD ROM BC-5500S 1.03" opened in OS access mode.
Opening files on harddrive at /Volumes/Drobo/Avatar (2009)/
Evaluation version, 26 day(s) out of 30 remaining
Edit: A quick reboot seemed to solve the problem. Keep up the good work!
setarip_old
Post by setarip_old » Sat May 01, 2010 8:15 pm
@dtblair
Hi!
The "SVQ" files only come into play when a BluRay disc contains a specific type of additional copy protection called "BD+". Thusfar, ONLY 20th Century Fox has used "BD+" and they've only used it on SOME (not all) of their BluRay releases.
If you install the latest version of "allcombo.svq" (Proper processing of "BD+" BluRay discs up to and including "Avatar") and, if necessary, any future updates, you'll be a happy camper ;>}
dtblair
Post by dtblair » Sat May 01, 2010 10:03 pm
setarip_old wrote:@dtblair
Avatar is the first disc that I've encountered with BD+. I've set up the allcombo.svq directory. Thanks for the info.
setarip_old
Post by setarip_old » Sun May 02, 2010 12:05 am
As always, my pleasure ;>}
Tommye1078
Post by Tommye1078 » Sun May 02, 2010 2:41 pm
Hey Guys
I am using OS X 10.6.3. I have downloaded the SVQ file. When I try to point MakeMKV to the file it is grayed out making it a unavailable choice. Is there a Mac SVQ or what am I doing wrong?
setarip_old
Post by setarip_old » Sun May 02, 2010 6:40 pm
@Tommye1078
Hi!
As per the instructions:
In order to use SVQ file just download it into "SVQ directory" set in MakeMKV preferences (on BD+ tab). MakeMKV will automatically pick-up the SVQ file and all discs that are enabled in SVQ file will start working. You must set "SVQ directory" in preferences, but you need to do it only once.
Tommye1078
Post by Tommye1078 » Sun May 02, 2010 7:20 pm
I still having problems getting the SVQ to work.
I've been going to BD+ tap in the preferences and I select the "browse folder" for the SVQ files directory. When I make my way to the location of the SVQ file in my downloads folder it is unelectable, you can see that it is there but is not able to be chosen.
Any help would be very much appreciated.
Tom
setarip_old
Post by setarip_old » Sun May 02, 2010 8:52 pm
@Tommye1078
Sorry to hear that you're still having difficulty.
Perhaps "NomadCF" or "Mike Admin" can provide you with a better/clearer explanation than I have...
