Concussion - Will Smith
Hannahbob62
#1 Post by Hannahbob62 » Fri Aug 12, 2016 2:12 pm
I cannot get this ripped. Starts out ok then just sits there. Any help would be grateful
yorgo
Re: Concussion - Will Smith
#2 Post by yorgo » Fri Aug 12, 2016 4:07 pm
Hannahbob62 wrote:I cannot get this ripped. Starts out ok then just sits there. Any help would be grateful
More info please. DVD or Blu-Ray, retail copy (where) or rental (where), country, etc. Does MakeMKV do or show anything in the status window when it just sits there?
Hannahbob62
#3 Post by Hannahbob62 » Sat Aug 13, 2016 11:27 pm
It is a Blu-Ray, Rental (netflix) USA, Message I get: error 'Scsi error"- medium error:L-EC- uncorrectable error" occurred while reading"/BDMV/STREAM/00001.M2bs"at offset'3514626048"
#4 Post by Woodstock » Sun Aug 14, 2016 1:07 am
Rental disks are often very dirty and scratched. When I had a Netflix disk subscription, I often had to clean/wax disks to get them to play.
Of course, I also received some that were broken...
Hannahbob62
#5 Post by Hannahbob62 » Sun Aug 14, 2016 2:36 pm
Disk seems almost new, free of scratches or blemishes.
Hannahbob62
#6 Post by Hannahbob62 » Sun Aug 14, 2016 5:03 pm
MakeMKV_log.txtDebug log started at Sun Aug 14 16:39:38 2016 , written by MakeMKV v1.10.1 darwin(x86-release)
001005:0000 MakeMKV v1.10.1 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Ollie/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS00d" opened in OS access mode.
001003:0020 DEBUG: Code 100864261 at c+vi!lj?WVY9h^og:121269731
001003:0020 DEBUG: Code 100864261 at +f%qQyRW~6x&R"zZ3I:213131686
001003:0020 DEBUG: Code 100864261 at +f%qQyRW~6x&R"zZ3I:29393930
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00343.m2ts' at offset '203311104'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00343.m2ts' at offset '166146048'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00343.m2ts' at offset '932683776'
DEBUG: Code 2147483648 at /^]Q_MF70x^<b(Rl:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=sWLOOkx5qQje2N6am3mWJXHvbFUOXFVyqP/iH4Nmakcmp76qfZrsM9Hm6a6qPTw1dZ3J5r1Md8tfcH6KKh1YeTLpI+Onk8VgBIFlqgbBDeZcDllwcgPhz9FZywQQhDUBb4mIcDGW54dBcInLSW6uwFmIzwuFwtJy9g==
DCE=rXDcyecgv8+pGbJjz2rNDNGUpYRDl0LOkIae0+2fgN4MUPSQYcwYU0Dj5zm3Dw8OsPp92+fAh4Z3U6eFmS/WM/qzsVj+GW/ih57xYkpXvz+l9nUbgCL0nwEPGCLdbzIawpbzMIzTCpg8nkf6O83n0zLHiW/wQCfU+Q==
DISCID=59E005ED2B0F9982DB34DE5C06164189B61C958E
003307:0000 File 00102.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003307:0000 File 00095.mpls was added as title #2
003307:0000 File 00096.mpls was added as title #3
003307:0000 File 00352.mpls was added as title #4
003025:0000 Title #00353.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00354.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00355.mpls has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00356.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00357.mpls has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00358.mpls was added as title #5
003025:0000 Title #00359.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00360.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00361.mpls has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00099.m2ts was added as title #6
003025:0000 Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00334.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00335.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00336.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00339.m2ts was added as title #7
003025:0000 Title #00340.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00341.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00343.m2ts was added as title #8
003307:0000 File 00344.m2ts was added as title #9
003307:0000 File 00345.m2ts was added as title #10
001003:0020 DEBUG: Code 2049 at 9c$-v7#P%Vt-88d#:29402601
001003:0020 DEBUG: Code 513 at 9c$-v7#P%Vt-88d#:29402601
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00346.m2ts' at offset '915456'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00346.m2ts' at offset '1308672'
DEBUG: Code 100864261 at +f%qQyRW~6x&R"zZ3I:213130904
003307:0000 File 00346.m2ts was added as title #11
003025:0000 Title #00347.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00348.m2ts was added as title #12
003307:0000 File 00349.m2ts was added as title #13
003307:0000 File 00350.m2ts was added as title #14
003025:0000 Title #00351.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/Ollie/Movies/Concussion_(2015)
001003:0020 DEBUG: Code 1073741829 at j6h#7["(uN_[?Gao:29393953
001003:0020 DEBUG: Code 4097 at 9c$-v7#P%Vt-88d#:29402601
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3549689856'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '3549689856'
DEBUG: Code 1073741829 at +f%qQyRW~6x&R"zZ3I:213130904
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3549689856'
001003:0020 DEBUG: Code 0 at 2Eh[BZ:!"Rv1C Et]V}E:121263291
001003:0020 DEBUG: Code 0 at 1>UJW,$s6O6Ec33zNC^7:121262302
001003:0020 DEBUG: Code 0 at 2Eh[BZ:!"Rv1C Et]V}E:213130812
001003:0020 DEBUG: Code 1733247 at 2Eh[BZ:!"Rv1C Et]V}E:29393286
001003:0020 DEBUG: Code 0 at {e)?BILU9seTNzhK|F$[":29398967
005003:0000 Failed to save title 1 to file /Users/Ollie/Movies/Concussion_(2015)/Concussion_(2015)_t01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun Aug 14 17:00:02 2016
yorgo
#7 Post by yorgo » Mon Aug 15, 2016 1:02 am
Just because the disc looks clean and not scratched does not mean that there isn't some kind of mastering error that prevents a good rip. I've had this happen often enough. Replace the disc.
Hannahbob62
#8 Post by Hannahbob62 » Mon Aug 15, 2016 9:33 am
Okies, TY
