Mac OS 10.11.6 El Cap
davey1107
Post by davey1107 » Wed Aug 10, 2016 8:51 pm
For about six months (since Yosemite) I've experienced an error where MakeMKV can create a full disc backup, but Handbrake can no longer read the produced files. I can still create readable MKVs of the files. I'm on OS 10.11.6, and the issue is consistent across several macs.
Has anyone experienced this issue, is there a workaround, and does anyone know whether the issue is on the MakeMKV or Handbrake side?
Re: Mac OS 10.11.6 El Cap
Post by Woodstock » Thu Aug 11, 2016 6:27 am
Do you get different results if you have MakeMKV open the disk, then create MKV files directly, instead of doing a backup?
Well over a year ago, there was an issue with OS X where it "took control" over directories named "bdmv", and caused issues. But that was resolved by changing the case of the directory name in most programs, MakeMKV included.
I use MakeMKV with handbrake on a near daily basis, but not on OS X, and I avoid the "backup" function for other reasons.
bdkennedy1
Post by bdkennedy1 » Fri Aug 12, 2016 1:47 am
I think Apple changed something with OS X 10.11.6 because I'm getting a ton of rip failures. For 6 months I've ripped dozens of Blu-ray discs with no problem and now all of a sudden I have 5 discs sitting in front of me that fail to rip, and it seems it started when I upgraded to 10.11.6
Burlesque
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '17035751424'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '17035755520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '17035751424'
Batman Begins
Error 'Scsi error - MEDIUM ERROR:DATA SYNCHRONIZATION MARK ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '14943977472'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '14943977472'
No Country for Old Men
Waiting...
Finding Nemo
Post by Woodstock » Fri Aug 12, 2016 2:48 am
What drive are you using?
When the errors occur, what rip speed are you reaching just before they start?
DavidHOO
Post by DavidHOO » Tue Aug 16, 2016 8:22 am
Last year, when I firstly upgraded to El Capitan, both my MakeMKV and Handbrake were out of work. I had to turn to a cheaper software called ByteCopy, supporting new 10.11 system. But several months went by, I re-installed MakeMKV and it worked again. I think your upgrade makes your Makemkv something wrong. You can try to uninstall and re-install your software.
