Can't get anything to work
MovieGuy34
Post by MovieGuy34 » Fri Aug 05, 2016 2:48 am
Either it says my drive doesn't have a disk or it gives me this error:
DEBUG: Code 0 at @ye;*W9s.@]g_30^_I:29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:39726b33daaf2687:TSSTcorp BDDVDW SE-506BB TS00'
DEBUG: Code 0 at @ye;*W9s.@]g_30^_I:29396345
DEBUG: Code 4 at @ye;*W9s.@]g_30^_I:121262647
Highest AACS version is v50 , MKB saved as /Users/lon/.MakeMKV/MKB_v50_OUTCAST.tgz
DEBUG: Code 0 at 1CmUQ&6a$5gT1V)Y:213132054
DEBUG: Code 0 at 1CmUQ&6a$5gT1V)Y:121266028
Any ideas? I'm not smart enough to figure this out on my own.
Re: Can't get anything to work
Post by Woodstock » Fri Aug 05, 2016 1:57 pm
If the disk isn't being detected in the drive, that is usually caused by the operating system "forgetting" how to talk to the drive. Since this is a USB drive, you can reset the operating system's parameters by unplugging the drive, then plugging it back in after the system notices that it is missing.
As for the actual reading of the disk, are you getting errors with ALL disks (BD and DVD), just BDs, or just one particular BD?
Just one disk could be an error in the directory area of the disk, often just a surface dirty enough to distort the laser, causing a read error.
