Work with Mac El Cap 10.11.6?
GTrent71
Post by GTrent71 »
I want to purchase MakeMKV but I hear it does not work with latest Mac OS. Can someone confirm?
Thank you.
Re: Work with Mac El Cap 10.11.6?
Where did you hear that from? No one has posted issues recently about OS X compatibility issues.
GTrent71
Post by GTrent71 »
I heard it around the way. Glad to hear it's not an issue.
So when I buy the MakeMKV, I should choose OS 10.10 Yosemite or the Other?
Thank you.
That should work.
The question on the purchase form is more for demographics than anything else - the key works for all versions (OS X, Window, Linux), and the download is separate (same file you've already downloaded).
