How do i get it to work?
wetryszdjgkx
Post by wetryszdjgkx »
I start the MakeMKV program and it tells me to download the new version when i already have it or to put in a registration key. I checked the forums and i put in one i found and it had expired, What is the current registration key?
Re: How do i get it to work?
Until a new beta key is issued, you need to set the DATE back on your machine to 7/20, start MakeMKV, then reset your system date.
Once the new key is issued, you would enter the new key after you start MakeMKV, and you won't have to change the date.
