MKV v 1.10
reol09
MKV v 1.10
Post by reol09 » Tue Aug 02, 2016 1:28 am
Hi everyone. I a few months ago I purchased the MKV licensed. I am on v 1.9.9. I noticed that v1.10 is out. How do I upgrade? I checked to see if there was an "check for update" option anywhere on the menu of the software, but could not find anything. I am using the Mac version of the program. Thank you in advance for your help.
Re: MKV v 1.10
Post by Woodstock » Tue Aug 02, 2016 2:13 am
Upgrade procedure: Download new version install file. Run it. Follow prompts.
The main thing to watch for is that you allow the old version to finish uninstalling before you start installing the new version.
The other thing to watch for is, if you have customized any profiles, you copy them to the MakeMKV data directory before updating. The entire MakeMKV program directory is deleted during the uninstall, so your custom profiles need to be elsewhere, and the data directory is where that "elsewhere" should be.
You can find the MakeMKV data directory by going to Preferences->General.
Lovely Rita
Re: MKV v 1.10
Post by Lovely Rita » Tue Aug 02, 2016 4:11 am
Woodstock wrote:Upgrade procedure: Download new version install file. Run it. Follow prompts.
In a Windows world, yes......but it's a little different (simpler?) on our Macs.
All we have to do is download the new version, which is in a .dmg (image) file, open it and drag/drop or copy/paste the new version to the Applications folder. A message will appear alerting us to the fact that an older version exists, do we wish to delete it or keep both files. In my case I usually keep a couple of recent builds until I'm satisfied the latest version operates correctly.
And we never have to worry about custom profiles not being carried over. 8)
Registered User :wink:
Buy MakeMKV
br408408
Re: MKV v 1.10
Post by br408408 » Wed Aug 03, 2016 10:37 pm
In a Linux world, it is also like a Mac, you don't loose anything that you customized
reol09
Re: MKV v 1.10
Post by reol09 » Sun Aug 07, 2016 6:32 pm
Awesome. Thanks guys!
