Cannot Find Optical Drive
jrester
Post by jrester »
Not sure what is happening but for some reason the program is making my dvd drive disappear. It will work on a few dvds and then it says it cannot find optical drive and my dvd reader wont work with any program. I have removed upper and lower filters as per a windows 7 tutorial which helped only for a short period of time. Any help?
craignan
Re: Cannot Find Optical Drive
Post by craignan »
Try a right click on the application icon and select 'Run as Administrator'
jrester
Post by jrester »
Thank you. I will try that!
jrester
Post by jrester »
Ok, so I have tried to run as administrator and I still have the same issue...
Any other suggestions?
Question - you're able to rip after rebooting, but eventually Windows stops acknowledging the presence of the drive?
This has happened to me on occasion. Windows gets confused and thinks the disk you ejected is still in the drive, and nothing short of a reboot will bring it back.
Sometimes, I would notice something running in the Task Manager that shouldn't be, like several copies of makemkvcon, when I only have one copy of the graphic user interface up, but other times, there was nothing out of the ordinary, other than the drive "wasn't there" in Windows.
With external drives, it is easy enough to unplug then replug, but internal drives require a reset.
