Unbroken
mukuld50
Unbroken
#1 Post by mukuld50 » Sun Jul 31, 2016 11:19 pm
Hello - I am having issues converting the Unbroken bluray to a .mkv. I ripped the bluray using Redfox, and then am trying to convert it to an mkv. Here are the errors. Any help would be appreciated. Thank you very much.
Opening files on harddrive at D:/Working Files/UNBROKEN_NA
AACS directory not present, assuming unencrypted disc
File 00300.mpls was added as title #0
Title #00301.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00302.mpls was added as title #1
Title #00303.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00304.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00305.mpls was added as title #2
Title #00306.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00307.mpls was added as title #3
Title #00308.mpls has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00311.mpls was added as title #4
File 00312.mpls was added as title #5
File 00313.mpls was added as title #6
File 00385.mpls was added as title #7
File 00800.mpls was added as title #8
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00312.m2ts was added as title #9
File 00313.m2ts was added as title #10
File 00314.m2ts was added as title #11
File 00315.m2ts was added as title #12
File 00316.m2ts was added as title #13
File 00317.m2ts was added as title #14
File 00318.m2ts was added as title #15
Title #00350.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00353.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00354.m2ts was added as title #16
Title #00355.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00357.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00358.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00359.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00360.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00361.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00363.m2ts was added as title #17
Title #00364.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00368.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00369.m2ts was added as title #18
Title #00370.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00371.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00372.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00373.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00374.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00375.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00376.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00377.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00378.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00379.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00380.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00381.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00383.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00384.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50357.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50358.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50359.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Working Files
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '17158717440'
Failed to save title 8 to file D:/Working Files/Unbroken_t08.mkv
0 titles saved, 1 failed
Re: Unbroken
#2 Post by Woodstock » Mon Aug 01, 2016 12:10 am
It is very unusual to get errors like this from a hard drive - they aren't supposed to go "offline" without you turning them off.
Since you're saving to the same device you are reading from, it is possible either the drive or the operating system got confused.
mukuld50
Re: Unbroken
#3 Post by mukuld50 » Mon Aug 01, 2016 12:16 am
Woodstock wrote:It is very unusual to get errors like this from a hard drive - they aren't supposed to go "offline" without you turning them off.
I see, that makes sense. I have ripped a few other blu-rays just fine now. I will try restarting my computer / re-rip the bluray maybe and see if that works.
