HEVC Support
yorgo
Re: HEVC Support
Thanks, guys!
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
docbill
Re: HEVC Support
If you want to convert your video or audio tracks, then use a program like Handbrake.mkvuser1 wrote:Can you please add HEVC/H265/X265 codec support?
Having HEVC/H265/X265 codec support would be handy for converting the audio for mkv files with HEVC/H265/X265 video.
For example you may have a mkv with HEVC/H265/X265 video and flac audio
if makemkv had HEVC/H265/X265 codec support you could convert the audio from flac to aac
archer75
Re: HEVC Support
I just use handbrake to covert whatever I want to convert. I use plex as well but it's not transcoding as my hardware supports h.265 and the HDaudio tracks so it direct plays.
troyBORG
Re: HEVC Support
I usually just use ffmpeg to encode my rips to HEVC..
(Gave me a 5.13 GB file)
I copy the subs and the audio and re-encode the video, and crop the black out so I can see it on my 21:9 monitor.
If you wanna encode the audio also, just replace the "-acodec copy" with "-codec:a aac -ab 768k"
ffmpeg -i Now_You_See_Me_2_t248.mkv -vf crop=1920:800:0:140 -codec:v libx265 -crf 18 -preset slow -scodec copy -acodec copy "I:\Video\H265\Now You See Me 2.mkv"
