Correct .mpls for Criminal
tron21net
Re: Correct .mpls for Criminal
Post by tron21net »
outdoorguy568 wrote:ANY says 559.mpls for Red.
Confirmed. 559.mpls played completely correct without any segment swaps/repeats nor copying messages.
Title information
Name: Criminal (English)
Source file name: 00559.mpls
Duration: 1:53:34
Chapters count: 16
Segment count: 20
Segment map: 514,512,503,517,501,506,520,515,504,508,502,511,519,510,509,513,507,518,505,516
File name: Criminal_t157.mkv
Boggs47
Post by Boggs47 »
Has anyone run into this issue before, this is the first time I have seen this. I tried to search and nothing came up.
Using Java runtime from /System/Library/Frameworks/JavaVM.framework/Versions/Current/Commands/java
gereral1
Post by gereral1 »
RickInHouston wrote:989 for red isn't correct. ProcMon locks on that mpls, for some reason for me, as well. It's not being cached, so I don't know why it is working that way.
Watch the scene where he goes to wife's house. she's bound. he looks to the phone, it rings (phone should ring, then he looks at it). she's loose. you never see her make the alarm go off with her toe...
989 is wrong.
559 is playing well in that part, as well as arriving at the not-cement factory scene as mentioned in an earlier post.
My vote is for 559 - how did you arrive at that?
If you are using licenced player with original can you post screen shot of proc monitor mpls line so I can see it. I've heard as of recent movies this method no longer works. If this does not work set .m2ts filter same as mpls filter and fast forward movie and write down the segment calls to get the correct order. You might have to use bdedit to view each mpls till you find the segment order. This kinda sucks but will work. Been awhile since I've rented any new movies to look at this new screen pass
dashocker
Post by dashocker »
AAnyone confirm mpls 989 is correct for netflix?
hvnphoto
Post by hvnphoto »
Can anyone confirm the correct playlist for the retail copy? It was posted as 869 earlier in the thread but Process Monitor is no longer reliable. I will attempt to play the movie to verify if 869 is correct. Thanks.
taseldor
Post by taseldor »
Boggs47 wrote:Has anyone run into this issue before, this is the first time I have seen this. I tried to search and nothing came up.
If your Java's up to date and you're on a Mac you probably need this: https://support.apple.com/kb/DL1572?locale=en_US
Boggs47
Post by Boggs47 »
Thanks that worked, much appreciated!!!!! :D :D :D :D
tenjuna
Post by tenjuna »
989 is incorrect for Netflix Bluray, the cab scenes are swapped as talked about earlier in thread, I just ripped it. Trying 559 and 869 mentioned in thread.
tenjuna
Post by tenjuna »
559.mpls is correct for the Netflix Bluray
zoxxo
Post by zoxxo »
tenjuna wrote:559.mpls is correct for the Netflix Bluray
Just curious, how did you verify the correct selection?
maddog510
Post by maddog510 »
Anyone figure out the correct playlist for the retail version yet?
maddog510
Post by maddog510 »
No one tried where it says FPL_MainFeature or is that a trick? 00757 mpls; title 3.
mariors44
Post by mariors44 »
maddog510 wrote:No one tried where it says FPL_MainFeature or is that a trick? 00757 mpls; title 3.
incorrect playlist for me.
tenjuna
Post by tenjuna »
I watched it after ripping it, no problems.
Baggs
Post by Baggs »
Title information
Duration: 1:53:34
Chapters count: 16
Segment count: 20
