Whiskey Tango Foxtrot gives me the following errors. I searched the forum and this was a protection issue that was fixed a few years ago. Bad disk? Something else?
MakeMKV v1.10.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Office/MakeMKV_log.txt
LIBMKV_TRACE: UDF: BROKEN DIRECTORY ENTRY
DEBUG: Code 0 at Gf|P[%{J %):KAF:121261819
DEBUG: Code 0 at Gf|P[%{J %):KAF:29393884
DEBUG: Code 1 at A?I-\4OU_eyEk4F?X:121263130
DEBUG: Code 0 at T=]"v)$7&SYuqp:213143646
DEBUG: Code 0 at RZmYxs$/kz/Rpo0u:29398139
DEBUG: Code 0 at RZmYxs$/kz/Rpo0u:121263797
DEBUG: Code 0 at RZmYxs$/kz/Rpo0u:121266028
Re: BROKEN DIRECTORY ENTRY
Haven't seen this error before, and other than the message that Mike replied to back in 2014, I don't see a sure-fire fix. Maybe Mike can make something out from the debug messages...
Wondering if my BD player has an issue. I just replaced a bad one a year ago and it has been working great.Woodstock wrote:Haven't seen this error before, and other than the message that Mike replied to back in 2014, I don't see a sure-fire fix. Maybe Mike can make something out from the debug messages...
SOLVED
Turned out it was my LG BD read/writer.
Windows 10 was not loading it properly. I googled, found that if I go to device manager and delete ATA channels 0 and 1 and reboot it should fix the driver loading issue. It did and now I don't need to order a new one
