[SOLVED] v1.10.0 doesn't decrypt Now You See Me (UK)
qlb1234
#1 Post by qlb1234 » Tue Jul 26, 2016 1:44 am
Drive: Pioneer BDR-S08XLB
OS: Windows XP SP3
MakeMKV version: v1.10.0
Disc: Now You See Me (UK version)
This is the first time this drive reads a Blu-ray disc. With the same drive and disc, it plays well with VLC on Linux.
Here's the log.
MakeMKV v1.10.0 win(x86-release) started
Evaluation version, 26 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v40 , MKB saved as C:\Documents and Settings\Administrator/.MakeMKV/MKB_v40_NOW_YOU_SEE_ME.tgz
Here's some other info.
Manufacturer: VBOX
Product: CD-ROM
Revision: 1.0
Serial number: OJDL529599WL
Firmware details: intf=REC gen=8301 krnl=ID92 main=ID92 ver=0000
Firmware date: 2014-12-18
Highest AACS version: 40
Disc Information
Label: NOW YOU SEE ME
Timestamp: 2013-09-03 08:02:08
Data capacity: 44.96 Gb
Disc type: BD-ROM
Number of layers: 2
Solution:
Download KEYDB.cfg from http://vlc-bluray.whoknowsmy.name/ and put it in ~/.MakeMKV. The path depends on the settings in MakeMKV.
qlb1234
Re: v1.10.0 doesn't decrypt Now You See Me (UK)
#2 Post by qlb1234 » Thu Jul 28, 2016 9:14 am
Good lord. After some serious Googling, I found that I can tell MakeMKV to make use of KEYDB.cfg.
Long story short. Go http://vlc-bluray.whoknowsmy.name/ and download KEYDB.cfg. Put it under ~/.MakeMKV. ~/MakeMKV can be changed in MakeMKV settings.
I wish more people see this with the same problem.
Re: [SOLVED] v1.10.0 doesn't decrypt Now You See Me (UK)
#3 Post by Woodstock » Thu Jul 28, 2016 2:28 pm
Generally, the keydb file isn't needed, as long as MakeMKV can read the directory of the disk. It looks like in your case that isn't happening. WHY is a different question.
