[SOLVED] v1.10.0 doesn't decrypt Now You See Me (UK)
qlb1234
Post by qlb1234 »
Drive: Pioneer BDR-S08XLB
OS: Windows XP SP3
MakeMKV version: v1.10.0
Disc: Now You See Me (UK version)
This is the first time this drive reads a Blu-ray disc. With the same drive and disc, it plays well with VLC on Linux.
Here's the log.
MakeMKV v1.10.0 win(x86-release) started
Evaluation version, 26 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v40 , MKB saved as C:\Documents and Settings\Administrator/.MakeMKV/MKB_v40_NOW_YOU_SEE_ME.tgz
Here's some other info.
Manufacturer: VBOX
Product: CD-ROM
Revision: 1.0
Serial number: OJDL529599WL
Firmware details: intf=REC gen=8301 krnl=ID92 main=ID92 ver=0000
Firmware date: 2014-12-18
Highest AACS version: 40
Disc Information
Label: NOW YOU SEE ME
Timestamp: 2013-09-03 08:02:08
Data capacity: 44.96 Gb
Disc type: BD-ROM
Number of layers: 2
Solution:
Download KEYDB.cfg from http://vlc-bluray.whoknowsmy.name/ and put it in ~/.MakeMKV. The path depends on the settings in MakeMKV.
qlb1234
Re: v1.10.0 doesn't decrypt Now You See Me (UK)
Post by qlb1234 »
Good lord. After some serious Googling, I found that I can tell MakeMKV to make use of KEYDB.cfg.
Long story short. Go http://vlc-bluray.whoknowsmy.name/ and download KEYDB.cfg. Put it under ~/.MakeMKV. ~/MakeMKV can be changed in MakeMKV settings.
I wish more people see this with the same problem.
Re: [SOLVED] v1.10.0 doesn't decrypt Now You See Me (UK)
Generally, the keydb file isn't needed, as long as MakeMKV can read the directory of the disk. It looks like in your case that isn't happening. WHY is a different question.
