tron21net
Post
by tron21net » Wed Jul 27, 2016 10:06 pm
outdoorguy568 wrote:ANY says 559.mpls for Red.
Confirmed. 559.mpls played completely correct without any segment swaps/repeats nor copying messages.
Title information
Name: Criminal (English)
Source file name: 00559.mpls
Duration: 1:53:34
Chapters count: 16
Segment count: 20
Segment map: 514,512,503,517,501,506,520,515,504,508,502,511,519,510,509,513,507,518,505,516
File name: Criminal_t157.mkv
Boggs47
Post
by Boggs47 » Wed Jul 27, 2016 11:55 pm
Has anyone run into this issue before, this is the first time I have seen this. I tried to search and nothing came up.
Using Java runtime from /System/Library/Frameworks/JavaVM.framework/Versions/Current/Commands/java
gereral1
Post
by gereral1 » Thu Jul 28, 2016 4:08 am
RickInHouston wrote:989 for red isn't correct. ProcMon locks on that mpls, for some reason for me, as well. It's not being cached, so I don't know why it is working that way.
Watch the scene where he goes to wife's house. she's bound. he looks to the phone, it rings (phone should ring, then he looks at it). she's loose. you never see her make the alarm go off with her toe...
989 is wrong.
559 is playing well in that part, as well as arriving at the not-cement factory scene as mentioned in an earlier post.
My vote is for 559 - how did you arrive at that?
If you are using licenced player with original can you post screen shot of proc monitor mpls line so I can see it. I've heard as of recent movies this method no longer works. If this does not work set .m2ts filter same as mpls filter and fast forward movie and write down the segment calls to get the correct order. You might have to use bdedit to view each mpls till you find the segment order. This kinda sucks but will work. Been awhile since I've rented any new movies to look at this new screen pass
dashocker
Post
by dashocker » Thu Jul 28, 2016 4:19 pm
AAnyone confirm mpls 989 is correct for netflix?
hvnphoto
Post
by hvnphoto » Thu Jul 28, 2016 4:41 pm
Can anyone confirm the correct playlist for the retail copy? It was posted as 869 earlier in the thread but Process Monitor is no longer reliable. I will attempt to play the movie to verify if 869 is correct. Thanks.
taseldor
Post
by taseldor » Fri Jul 29, 2016 6:08 pm
Boggs47 wrote:Has anyone run into this issue before, this is the first time I have seen this. I tried to search and nothing came up.
If your Java's up to date and you're on a Mac you probably need this:
https://support.apple.com/kb/DL1572?locale=en_US
tenjuna
Post
by tenjuna » Sat Jul 30, 2016 7:10 pm
989 is incorrect for Netflix Bluray, the cab scenes are swapped as talked about earlier in thread, I just ripped it. Trying 559 and 869 mentioned in thread.
tenjuna
Post
by tenjuna » Sat Jul 30, 2016 9:09 pm
559.mpls is correct for the Netflix Bluray
zoxxo
Post
by zoxxo » Sun Jul 31, 2016 2:49 am
tenjuna wrote:559.mpls is correct for the Netflix Bluray
Just curious, how did you verify the correct selection?
maddog510
Post
by maddog510 » Sun Jul 31, 2016 10:02 pm
Anyone figure out the correct playlist for the retail version yet?
maddog510
Post
by maddog510 » Tue Aug 02, 2016 5:30 am
No one tried where it says FPL_MainFeature or is that a trick? 00757 mpls; title 3.
mariors44
Post
by mariors44 » Sat Aug 06, 2016 12:39 am
maddog510 wrote:No one tried where it says FPL_MainFeature or is that a trick? 00757 mpls; title 3.
incorrect playlist for me.
tenjuna
Post
by tenjuna » Fri Aug 12, 2016 3:25 am
zoxxo wrote:tenjuna wrote:559.mpls is correct for the Netflix Bluray
I watched it after ripping it, no problems.
Baggs
Post
by Baggs » Sun Aug 14, 2016 6:09 pm
tron21net wrote:outdoorguy568 wrote:ANY says 559.mpls for Red.
Title information
Duration: 1:53:34
Chapters count: 16
Segment count: 20
