Convert a group of MKVs at once? Remove foreign audio?
boe_d
Post by boe_d »
I've used makemkv to convert an MKV file in the past to remove a foreign language audio track as it was the default one. I have a TV series and all the audio has German as the first language. I'd love not to have to change the language for each episode on my player. Is there a way with makemkv or another program to mass convert MKV files? There are only two audio languages on each mkv 1. German and the second is English.
Re: Convert a group of MKVs at once? Remove foreign audio?
Search for "mkvtoolnix". The mkvmerge utility that comes with it can re-order or remove tracks. There is a graphic interface to it, and it can be used to create a command line that can be edited to put into a batch file.
