BLAST DVD Error
boogy886
BLAST DVD Error
Post by boogy886 » Fri Jul 22, 2016 2:47 am
DVD fails to open. Any help would be appreciated. Log contents below:
Debug log started at Fri Jul 22 02:26:38 2016 , written by MakeMKV v1.10.0 linux(x64-release)
001005:0000 MakeMKV v1.10.0 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as MakeMKV_log.txt
003019:0000 Cells 25-end were skipped due to cell commands (structure protection?)
003024:1000 Complex multiplex encountered - 24 cells and 6377 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
001003:0020 DEBUG: Code 0 at veFS$hZl\V4eU*-mz&Hh6JZ:213130122
003028:0000 Title #1 was added (24 cell(s), 1:31:42)
Title skip vts=1 pgcn=1 hash=BD8B491B1FAC18E4
003025:0000 Title #2 has length of 3 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #4 has length of 12 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #5 has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #6 has length of 1 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #14 has length of 131 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #16 has length of 68 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #17 has length of 109 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #18 has length of 100 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #19 has length of 94 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
001003:0020 DEBUG: Code 1 at AD6)MpL'Y2&+6:213132422
001003:0020 DEBUG: Code 0 at sH(5OQ{ 7wkt!=L-R*:213140633
001003:0020 DEBUG: Code 0 at QU{9IjWe[cU|kUVE:121271548
001003:0020 DEBUG: Code 0 at QU{9IjWe[cU|kUVE:121265798
001003:0020 DEBUG: Code 0 at QU{9IjWe[cU|kUVE:29403866
001003:0020 DEBUG: Code 0 at sH(5OQ{ 7wkt!=L-R*:121276999
001003:0020 DEBUG: Code 1 at {YjPV&[9TD2\GwiV:213130789
001003:0020 DEBUG: Code 0 at Pb|rHK]i'AeMdtw:213139299
001003:0020 DEBUG: Code 0 at t^0Q5@os?#NRM0:29398530
001003:0020 DEBUG: Code 233 at vWmvuvJT2GHkwWEFjxew/086:0
Re: BLAST DVD Error
Post by Woodstock » Fri Jul 22, 2016 12:26 pm
Based on what Mike has said in the past, the debug errors tend to indicate that there is an issue with reading the disk. There is not an actual ERROR being reported, but the data MakeMKV got back did not make sense. Some drives will do this when they can "mostly" read the disk, but not quite.
I would suggest cleaning the disk with a damp soft cloth. Then try it again.
boogy886
Re: BLAST DVD Error
Post by boogy886 » Sat Jul 23, 2016 5:01 pm
Woodstock wrote:Based on what Mike has said in the past, the debug errors tend to indicate that there is an issue with reading the disk. There is not an actual ERROR being reported, but the data MakeMKV got back did not make sense. Some drives will do this when they can "mostly" read the disk, but not quite.
Oh okay, good info. I didn't realize it was always going to be a dirty/damaged disk issue. Thanks for the help as usual Woodstock!
