Batman v Superman Dawn of Justice - Problems ripping
ILovMy07Sky
Post by ILovMy07Sky »
Anybody getting an error trying to rip the new Batman v Superman Blu-ray? Here are some details:
- OSX 10.11.5 (I've also tried it on a Win Server 2008r2)
- MakeMKV 1.10.0
- Source File Name = 00100.mpls
Here is the error:
MakeMKV v1.10.0 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/daddy/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5970H 3APEd" opened in OS access mode.
Optical drive "BD-RE BUFFALO Optical Drive 2.00d" opened in OS access mode.
DEBUG: Code 0 at rxn5@R{*?vI67_:121262164
DEBUG: Code 0 at 1CmUQ&6a$5gT1V)Y:213136079
Title #00023.mpls has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00024.mpls has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00025.mpls has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00055.mpls has length of 340 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
File 00100.mpls was added as title #0
Title #00017.mpls has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00010.m2ts has length of 56 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00011.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00016.m2ts has length of 50 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00033.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00034.m2ts has length of 154 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00039.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00040.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00041.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00018.m2ts has length of 340 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00069.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00056.m2ts has length of 905 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00078.m2ts has length of 46 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00084.m2ts has length of 1 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00088.m2ts has length of 748 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00089.m2ts has length of 1366 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00090.m2ts has length of 432 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00091.m2ts has length of 315 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00092.m2ts has length of 753 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00093.m2ts has length of 277 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00094.m2ts has length of 1276 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00095.m2ts has length of 428 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00096.m2ts has length of 495 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00097.m2ts has length of 408 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Saving 1 titles into directory /Users/daddy/Movies/Batman_v_Superman_Dawn_of_Justice
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '3598381056'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3598381056'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3598385152'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '3598577664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '3598774272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '3624794112'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3624794112'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3624796160'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3624800256'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '3625058304'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3625058304'
DEBUG: Code 1073741829 at %/j)EhW& 3TU#;:0Nb:121262969
DEBUG: Code 100864261 at %/j)EhW& 3TU#;:0Nb:121262969
DEBUG: Code 0 at c"\FAy"z.jRb:X5Pm2+B:121263291
DEBUG: Code 0 at y~x0GnqY(^B293Ep[ifx:121262302
DEBUG: Code 0 at c"\FAy"z.jRb:X5Pm2+B:213130812
DEBUG: Code 1770048 at c"\FAy"z.jRb:X5Pm2+B:29393286
DEBUG: Code 0 at &N&wECOsZ`iM)7!h{gW0,:29398967
Failed to save title 0 to file /Users/daddy/Movies/Batman_v_Superman_Dawn_of_Justice/Batman_v_Superman_Dawn_of_Justice_t00.mkv
0 titles saved, 1 failed
Re: Batman v Superman Dawn of Justice - Problems ripping
The error progression matches two main scenarios.
One is dirty disk - even the light "film" of chemicals left by the machines that drop the disks into the case can cause issues on a disk that "looks clean". Cleaning the disk with a damp soft COTTON or microfiber cloth will usually work for this.
The other is a power issue with an external drive; if they're not plugged into a fully-powered USB port, MakeMKV can spin them up to speeds where the run out of power, and shut down momentarily. This can happen with laptop drives, which are internally powered, if the laptop isn't plugged into external power.
The (relatively) good news is that the error moves around, so your drive can read most of the bad areas with retries. You MIGHT get better results if you increase the number of retries in Preferences->IO. But cleaning the disk should be the first thing to try.
