Currently having a problem ripping any discs using Ubuntu 16.04 LTS. If I boot into Windows the discs rip fine so the HW is not an issue. Is there anything I need to install into a fresh install of Ubuntu so ripping will work. Logs Below.
The Bluray drive is connected over USB, if that make any difference.
Thanks Mat.
MakeMKV v1.10.0 linux(x64-release) started
Evaluation version, 29 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0638BC28D440985B8644EDC5C91F0E544CD to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..070C39A7E488B32A803675AC6F227742A5B to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03E51DAE1AEBBA98295F85048AB6BE3CCE0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09FE916B1F772AEB794B9F2E8A75B6AA33A to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..047CC2ABB2DDC305E24ABECCBE2947FC6DB to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00FAA609F950EF11878DFAAB55226E69A50 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0412B51B022051ABF18F7D447172ECF5D84 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B2CE89B0F5C44DA7D8DF053573EAFFDCD3 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B00498E81B4A0937A6D57D554913DEEB1B to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..075C1746B507FC2B88C6FDACC4B0C24A6D6 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02176B30EC16D6662CF61DE52ACAF8E5AB7 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C3BB8A9235845D3043B6753FA244588021 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0ECC665D8FE6690866477939C039AEB8534 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E89E00C2FF884BB20A74B9B04AEA8B5437 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF8F906C7D8888135D4752494C251140E4 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..039D8ED91347180CBB89794A224D66459A0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C51CA10CCD109703B7EBA6EFF25A1105FB to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B672399EC6DF40C8BB50F107C834E75280 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04B9E342B5E824D5EE33B14D81A517F00DC to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FB9A23676F3987974A2237C8558A33AEFB to device 'SG:dev_11:2'
Highest AACS version is v60 , MKB saved as /home/mat/.MakeMKV/MKB_v60_Goosebumps.tgz
Can't read AACS VID from disc
Re: Can't read AACS VID from disc
Did you insert the disk before or after starting MakeMKV?
There are some instances where the operating system will "take control" of a disk before MakeMKV, and things won't work right. Starting MakeMKV before inserting a disk usually fixes that. But I do not remember seeing reports of that happening with Linux.
MatOD
I have had a look at this tonight. Ubuntu is mounting the disk, I then unmount it and still get the same problem. The disk still appears in my launcher. How do I ensure that Ubuntu does not have it open?
Thanks Mat.
Thanks Mat.
FoxRaynard
I'm having the exact same issue. I switched off automounting but I'm still getting the error messages
cpare
Are you also on Ubuntu 16.04 TLS? I was considering upgrading this weekend but will hold off if this is a release issue.FoxRaynard wrote:I'm having the exact same issue. I switched off automounting but I'm still getting the error messages
