MakeMKV 4K Ripper
danBoi2016
MakeMKV 4K Ripper
any idea when u will be releasing MakeMKV update for ripping 4k uhd blurays?
MrVideo
Re: MakeMKV 4K Ripper
Not going to happen any time soon. If you had searched the forum you would have discovered that the AACS2.0 that is used with 4k UHD releases has not been hacked, yet.danBoi2016 wrote:any idea when u will be releasing MakeMKV update for ripping 4k uhd blurays?
danBoi2016
I KNOW THAT, JUST ASKING, AND BLURAY.COM ppl can "capture" 4k screenshots
yorgo
I always assumed screen capture is totally different from decrypting a disc.danBoi2016 wrote:I KNOW THAT, JUST ASKING, AND BLURAY.COM ppl can "capture" 4k screenshots
MrVideo's answer is both accurate and appropriate.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
MrVideo
So very true.yorgo wrote:I always assumed screen capture is totally different from decrypting a disc.danBoi2016 wrote:I KNOW THAT, JUST ASKING, AND BLURAY.COM ppl can "capture" 4k screenshots
