Unable to Specify MKV Filename
kaufmanj1973
Using MakeMKV Beta 1.9.10, you can adjust the "title," "filename," and "metadata" properties. However, using MakeMKV Beta 1.10.0, I no longer get this option. (I tried to attach screen shots, but got the message "Sorry, the board attachment quota has been reached.") Is this a bug, or did they remove the filename renaming feature?
Re: Unable to Specify MKV Filename
Make sure your settings have not changed - that pull-down is controlled by Preferences->Expert mode, which controls ALL advanced menus. If you open Preferences, and do not see the Advanced tab, Expert mode has been turned off.
