Default folder to save MKV in?
bossyman15
Post by bossyman15 »
Before the MakeMkv would default to E drive which is what I use to save MKV to. But after I got second Hard drive now MakeMKV defaults to O drive. I kept having to manually change it to E drive every time. I couldn't find any options to make it default to E drive.
Is there anyway to do this?
16442496
Re: Default folder to save MKV in?
Post by 16442496 »
Those E, O drives sounds like it is Windows?
Is this help?
Makemkv-->Settings-->Video--> Custom
MakeMKV 1.17.6
+ gddrescue
blufred
Post by blufred »
Thanks for the info. I was wondering also where / how to set the output file, as it had to be selected each time I use MAKEMKV
Lovely Rita
Post by Lovely Rita »
MAKEMKV Preferences / Video Tab
Default Destination:
None
Auto
Semi-Auto
Custom
Registered User :wink:
Buy MakeMKV
