Upgrade version not working
STARS76
Post by STARS76 »
I have been using version 1.9.5 on OS10.10.5 for a year with no issues. Upgraded to 1.9.10 and no blu ray (haven't tried DVD's) will open. The disc is registered and an attempt is made to read, then the disc will not open to show titles etc. Is there something I am missing between these two versions. Relaunched 1.9.5 and discs are opened as usual?
Re: Upgrade version not working
If you have debug logging turned on, what errors are you seeing in the log for each version?
STARS76
Post by STARS76 »
HI disc is Deadpool and the log is as below:
Debug log started at Thu Jul 14 18:53:50 2016 , written by MakeMKV v1.9.10 darwin(x86-release)
001005:0000 MakeMKV v1.9.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/brian/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVRTS09 Q909d" opened in OS access mode.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS01d" opened in OS access mode.
001003:0020 DEBUG: Code 83886085 at `-+6{6pNmTgC3Yr>:121269731
001003:0020 DEBUG: Code 83886084 at `-+6{6pNmTgC3Yr>:121269731
001003:0020 DEBUG: Code 268435459 at {or$HjO4PZ?<P\Y_b{<C@o;Iv$J:213130950
001003:0020 DEBUG: Code 2281701379 at N;87||f5zz=H&u>Wt_:29396092
001003:0020 DEBUG: Code 2281701379 at N;87||f5zz=H&u>Wt_:29393930
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS01' at offset '655360'
001002:0020 LIBMKV_TRACE: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS01' at offset '32768'
001003:0020 DEBUG: Code 0 at vlG4e|qi6~#Rt|9dVY!:213129777
001003:0020 DEBUG: Code 2281701379 at `-+6{6pNmTgC3Yr>:213134676
Application exited at Thu Jul 14 18:57:13 2016
STARS76
Post by STARS76 »
With version 1.9.5. But the file then was having video problems with blocking etc.
Debug log started at Thu Jul 14 19:18:23 2016 , written by MakeMKV v1.9.5 darwin(x86-release)
001005:0000 MakeMKV v1.9.5 darwin(x86-release) started
005075:0000 The new version 1.9.10 is available for download at /download/
DEBUG: Code 2147483648 at 0K<\5VaPS%JSml%2:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=y7iGu/uigyGaMOL7Wn011XqB6thzaAbUk3eUKpLPZOdIu0S2NxDmXfQRCASQCEhAlGXsHKBeAEnYngrU+KVesYhQU3wIUpY9fvhxDxgbrlrmuHTH3SvfMJh+BlI5oB+zKvo7QfeC+F8w2gLtWUb7lLFVBtg4BoEi6w==
DCE=fOasR5x4penZkWu2zfb7vPdu3zH4Fcv90rYPE8o37HYixVfa7FRP67HK0IjUxI+VZQl9eBe8XuSlLCixdrY0ArW9tbrkjssbLG8t1+MRwMq/KBdNMtDz5oQZW0a9a5EcZd5mGa7v1jmWUEc0G1uqfB4drGQO/1pLSg==
003338:0000 Downloading latest SVQ(s) to /Users/brian/Library/MakeMKV ...
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000150.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000151.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000152.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000153.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000154.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000155.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000156.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000157.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000158.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000159.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015a.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015b.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015c.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015d.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015e.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000015f.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000160.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000161.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000162.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000163.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000164.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000165.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000166.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000168.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000169.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016a.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016b.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016c.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016d.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016e.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000016f.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000170.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000172.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000173.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000174.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000175.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000176.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000177.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000178.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000179.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017a.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017b.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017c.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017d.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017e.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000017f.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000180.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000181.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000182.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000183.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000184.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000185.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000186.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000187.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000188.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000189.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018a.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018b.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018c.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018d.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018e.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000018f.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000190.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000191.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000192.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000193.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000194.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000195.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000196.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000197.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000198.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/00000199.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019a.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019b.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019c.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019d.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019e.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/0000019f.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a0.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a1.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a2.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a3.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a4.svq can't be processed by this version, please download latest program version from /
003329:0000 SVQ in /Users/brian/Library/MakeMKV/000001a5.svq can't be processed by this version, please download latest program version from /
003317:0000 Loaded 278 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
001003:0020 DEBUG: Code 0 at 5AKFb@ Wiz86?>o&Pv:213132422
003332:0000 Saved BD+ dump file as /Users/brian/Library/MakeMKV/dump_Deadpool_0CC386110E928534.tgz
003327:0404 BD+ code processed but no FUTs were obtained, errors may follow
DISCID=0CC386110E9285343277C5F59742838B9858A29D
003025:0000 Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00250.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00356.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #0
003307:0000 File 00800.mpls was added as title #1
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00328.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00301.mpls was added as title #2
003025:0000 Title #00302.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00303.mpls was added as title #3
003307:0000 File 00304.mpls was added as title #4
003307:0000 File 00305.mpls was added as title #5
003025:0000 Title #00306.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.mpls has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00309.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00310.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00313.mpls was added as title #6
003307:0000 File 00318.mpls was added as title #7
003307:0000 File 00320.mpls was added as title #8
003307:0000 File 00321.mpls was added as title #9
003307:0000 File 00322.mpls was added as title #10
003307:0000 File 00335.mpls was added as title #11
003307:0000 File 00335.mpls(2) was added as title #12
003307:0000 File 00335.mpls(4) was added as title #13
003025:0000 Title #00336.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00340.mpls was added as title #14
003025:0000 Title #00341.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00344.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00347.mpls was added as title #15
003025:0000 Title #00348.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00349.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00351.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00352.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00353.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00354.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00300.mpls was added as title #16
003309:0000 Title 00801.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02451.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01927.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02559.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02450.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02608.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02636.m2ts was added as title #17
003025:0000 Title #02657.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02628.m2ts was added as title #18
003307:0000 File 02629.m2ts was added as title #19
003307:0000 File 02640.m2ts was added as title #20
003307:0000 File 02641.m2ts was added as title #21
003025:0000 Title #02646.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02647.m2ts was added as title #22
003307:0000 File 02648.m2ts was added as title #23
003307:0000 File 02659.m2ts was added as title #24
003025:0000 Title #02705.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02713.m2ts was added as title #25
003307:0000 File 02710.m2ts was added as title #26
003307:0000 File 02714.m2ts was added as title #27
Application exited at Thu Jul 14 19:21:31 2016
I would think this is the key:
The drive is going off-line during the read. Is it plugged into a hub, or directly into the Mac? If it's a MacBook, is it plugged in while you're doing this?
