Thomas and Friends Tale of the Brave
WinstonSmith
Post by WinstonSmith »
For some reason I cannot get the Blu Ray of the film Thomas and Friends Tale of the Brave to rip. I am new to the forum, but not to ripping (though I am a click it and it works guy.) I've never had an issue with a BD before.
I would truly appreciate any help. Thanks!
Here is the log:
MakeMKV v1.9.10 win(x64-release) started
File 00800.mpls was added as title #0
File 00303.mpls was added as title #1
Title #00201.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00201.mpls(1) was added as title #2
Title #00300.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00300.mpls(1) is equal to title 00201.mpls(1) and was skipped
Title #00053.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00053.mpls(1) is equal to title 00201.mpls(1) and was skipped
File 00020.mpls was added as title #3
Title #00003.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #4
File 00007.m2ts was added as title #5
Title #00008.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory G:/BluRayRips/Thomas_TaleOfTheBrave
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '16728195072'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '16728195072'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '16731273216'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '16731273216'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '16731275264'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '16731275264'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '16731273216'
Failed to save title 0 to file G:/BluRayRips/Thomas_TaleOfTheBrave/Thomas_Tales_of_the_Brave_t00.mkv
0 titles saved, 1 failed
Re: Thomas and Friends Tale of the Brave
There are a few things that can cause this. Fingerprints and even the chemical "film" left over from the suction cups on the machines that load disks into their carriers can interfere with the laser to get the "cannot read medium" error. This is especially likely if multiple attempts come up with the error in approximately (plus or minus a few sectors). A simple cleaning usually takes care of the blurring, but any scratches or cracks are harder to deal with.
In your case, the system was able to move past the first errors with retries; it MAY help to increase the number of retries (Preferences->IO menu). But cleaning comes first, especially with any disks that have been handled by a child or someone under the influence of a child (sticky fingers ;) ).
WinstonSmith
Thank you so much. Cleaning the disc and upping the errors worked perfectly. I thought the disc was clean, but apparently not.
Thank you again, you've made me and my son very happy!
