So i eventually ended up here, i got a collection of Stanley Cubrick movies.
Second disc rendered me this
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19445379072'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '19445379072'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '19445383168'
Failed to save title 0 to file G:/Egna Filmer/A_Clockwork_Orange_t00.mkv
0 titles saved, 1 failed
Does it say anything to you more knowledgeable guys?
I came up short on a googlesearch
Regards Matt
A_Clockwork_Orange Error report
Re: A_Clockwork_Orange Error report
Your drive is having issues reading the disk.
Start with cleaning the disk. Fingerprints and scratches are the number 1 problem with reading disks.
When the disk drive goes off-line like yours did, it could also be a power problem; external drives are notorious for this, when there isn't enough power on the USB bus.
Pit boss
Woodstock wrote:Your drive is having issues reading the disk.
Ok, i´ll try that, it´s an internal drive so power shouldn't be an issue.
Thank you for an awsome program, and a quick response!
Regards
