Green Room multiple playlists
Anybody out there know which mpls works? There are a boat load of them. Thanks for your help.
Re: Green Room multiple playlists
Where you able to figure this out? I'm facing the same conundrum.
Nope. No luck. And I'm not sure how to locate the log file, so if that's something I need to do, I'm going to need a little help.
Is makemkv still looking for log files from playlist obfuscated movies? I remember awhile ago there was going to be a feature showing the correct playlist for these kinds of disks. I still have the disk so let me know if you would like me to do anything in that regard.
Any help you can provide would be appreciated.
Playlist 00764.mpls appears to be the correct one. However, I haven't actually tested or watched it yet, so I can't verify at the moment.
Title information
Source file name: 00764.mpls
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Segment map: 506,512,520,519,507,509,513,508,517,516,511,514,515,502,505,518,501,504,503,510
File name: Green_Room_t233.mkv
Testing now. Will let you know in a little while.
Bingo! We have a winner! Playlist 00764 is the right track. Thanks for everyone's help. Movie's awesome. Check it out.
Great! Thanks for reporting back. I'll be watching it as soon as I have a chance.
Thanks gents!
I still have the disk for 1 more day? Now that mpls has been determined does anyone want any logs from this? If so exactly what is needed and what do I need to do?
johng wrote:Is makemkv still looking for log files from playlist obfuscated movies? I remember awhile ago there was going to be a feature showing the correct playlist for these kinds of disks. I still have the disk so let me know if you would like me to do anything in that regard.
Did you need to enable a specific option to see this in the log? I turned on logging but only saw the same output as the main GUI presents. How did you get the info from the log?
Min says t236.mkv Might grab a small version and see if it's the same movie...eNoize wrote:Playlist 00764.mpls appears to be the correct one. However, I haven't actually tested or watched it yet, so I can't verify at the moment.
Title information
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Title information
Name: Green Room (2015) (US) (English)
Duration: 1:35:01
Chapters count: 16
Segment count: 20
File name: Green_Room_(2015)_(US)_t236.mkv
lata
zomorf
zomorf
Any one know which track to use for the Green Room Blu-Ray straight from the Box?
You should post the UPN number to be sure you're talking about the same disc. You'll find it on the back on the bar code underneath the bar code stripes.
