backup to a network server
speed32219
Post by speed32219 » Fri Apr 30, 2010 12:45 am
When using makemkv, when I select where to save file, it only gives me the option to save to my local environment. (home/usr)
Is there an option somewhere to save to a network samba server?
Krobar
Re: backup to a network server
Post by Krobar » Fri Apr 30, 2010 8:21 am
It works in the Windows version, you just enter the UNC.
I've not used the Linux version but maybe you could mount the SAMA/CIFS share and add a symbolic ink to it in your home directory.
