Green Room multiple playlists
CarsonRice
Post by CarsonRice »
Anybody out there know which mpls works? There are a boat load of them. Thanks for your help.
michaelP
Re: Green Room multiple playlists
Post by michaelP »
Where you able to figure this out? I'm facing the same conundrum.
CarsonRice
Nope. No luck. And I'm not sure how to locate the log file, so if that's something I need to do, I'm going to need a little help.
johng
Post by johng »
Is makemkv still looking for log files from playlist obfuscated movies? I remember awhile ago there was going to be a feature showing the correct playlist for these kinds of disks. I still have the disk so let me know if you would like me to do anything in that regard.
michaelP
Post by michaelP »
Any help you can provide would be appreciated.
eNoize
Post by eNoize »
Playlist 00764.mpls appears to be the correct one. However, I haven't actually tested or watched it yet, so I can't verify at the moment.
Title information
Source file name: 00764.mpls
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Segment map: 506,512,520,519,507,509,513,508,517,516,511,514,515,502,505,518,501,504,503,510
File name: Green_Room_t233.mkv
CarsonRice
Testing now. Will let you know in a little while.
CarsonRice
Bingo! We have a winner! Playlist 00764 is the right track. Thanks for everyone's help. Movie's awesome. Check it out.
eNoize
Post by eNoize »
Great! Thanks for reporting back. I'll be watching it as soon as I have a chance.
michaelP
Post by michaelP »
Thanks gents!
johng
Post by johng »
I still have the disk for 1 more day? Now that mpls has been determined does anyone want any logs from this? If so exactly what is needed and what do I need to do?
johng wrote:Is makemkv still looking for log files from playlist obfuscated movies? I remember awhile ago there was going to be a feature showing the correct playlist for these kinds of disks. I still have the disk so let me know if you would like me to do anything in that regard.
DJRumpy
Post by DJRumpy »
Did you need to enable a specific option to see this in the log? I turned on logging but only saw the same output as the main GUI presents. How did you get the info from the log?
zomorf
Post by zomorf »
eNoize wrote:Playlist 00764.mpls appears to be the correct one. However, I haven't actually tested or watched it yet, so I can't verify at the moment.
Title information
Duration: 1:35:01
Chapters count: 16
Segment count: 20
Min says t236.mkv Might grab a small version and see if it's the same movie...
Title information
Name: Green Room (2015) (US) (English)
Duration: 1:35:01
Chapters count: 16
Segment count: 20
File name: Green_Room_(2015)_(US)_t236.mkv
lata
zomorf
PeterJennings
Post by PeterJennings »
Any one know which track to use for the Green Room Blu-Ray straight from the Box?
DJRumpy
Post by DJRumpy »
You should post the UPN number to be sure you're talking about the same disc. You'll find it on the back on the bar code underneath the bar code stripes.
