MakeMKV is no longer updated
cameleon078
Post by cameleon078 »
No update since April. Do you know why makemkv is no longer updated??
Regards.
Lovely Rita
Re: MakeMKV is no longer updated
Post by Lovely Rita »
Hmmm, I must have missed the announcement that there would be no more updates.
As you can see from the update history, updates have ranged from a few weeks to a few months.
/download/history.html
Registered User :wink:
Buy MakeMKV
Chetwood
Post by Chetwood »
cameleon078 wrote:No update since April.
So? Any particular feature missing?
Ant93
Post by Ant93 »
Support for newer discs perhaps?
support for newer disks
In what way?
The current version supports AACS through v60 (officially), and unofficially supports v61. Have you encountered a newer AACS version? If so, send the information to Mike. AACS issues prompt most new releases, because they are serious.
As new versions of BD+ are encountered and people submit the required information, Mike has been providing updates for those via the existing SVQ mechanism. Several new versions have been dealt with in the past two months. BD+ isn't like AACS, because it does NOT require a new program version, and a BD+ issue will usually only affect a few disks, rather than shutting down access to all BDs.
I received an email from Mike last month saying that a bug that affects one of my disks will be fixed in the next release, but that seems to be delayed by his desire to figure out the play list obfuscation stuff first.
Meister_Proper
Post by Meister_Proper »
Yes, correct identification of right eye first 3D BDs. I really hope that this will fixed in the next update. Otherwise everything is perfect.
