Allegiant
msweetz
Allegiant
Post by msweetz »
what's the right title for the red version?
pd1215
Re: Allegiant
Post by pd1215 »
Yes, does anyone know the correct mpls file for Redbox? I hate playlist obfuscation! :x
Axehandler
Re: Allegiant
Post by Axehandler »
Title information
Source file name: 00838.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,520,501,517,511,519,512,503,502,516,510,506,518,504,515,514,508,505,509,507
File name: Allegiant_t254.mkv
gizmogeek
Re: Allegiant
Post by gizmogeek »
It's worse when you spend the money to buy it. I could use help with the BluRay/DVD/Digital HD US version. It would be much appreciated.
Axehandler
Re: Allegiant
Open MKV and look at the file list
ALL (or 95% of them) the Segment maps from MKV will begin with something (513 is the above example)
Open the folder to the STREAMS in the blu-ray.
Example : Allegiant\BDMV\STREAM
1) Now open the file 00513.m2ts and view the last 30 seconds or so...
2) Now go thru the other m2ts files to find the NEXT part of the video. (above was 520)
3) Now open the file 00520.m2ts and view the last 30 seconds or so... Repeat step 2...
I've found just knowing the 1st 3 segments (513,520,501) will generally give you only 1 file. MAYBE 2... that matches up in the MKV list.
feel free to repeat above steps till you match your file 100%.
BTW - to find this Segment, it took me about 3 mins.
Axe
nick2421
Re: Allegiant
Post by nick2421 »
Netflix US version appears to be 209.mpls via powerdvd and proc monitor.
Title information
Source file name: 00209.mpls
Duration: 2:00:33
Chapters count:20
Segment count: 20
Segment map: 513,501,520,517,511,503,519,512,502,516,510,506,508,515,505,509,504,518,514,507
File name: Allegiant_t66.mkv
Can anyone else confirm this is correct?
bartman
Re: Allegiant
Post by bartman »
nick2421 wrote:Netflix US version appears to be 209.mpls via powerdvd and proc monitor.
If you watch those first three segments in order, it is wrong. 513, 520, 501 flows correctly.
513, sitting in chair at end.
520, sitting at chair at start, standing at end.
501, standing at start.
tindivall
Re: Allegiant
Post by tindivall »
If 513, 520, 501 is indeed the correct starting order for the first 3 segments then only 1 fits, 838 as listed in the 3rd post by Axe
GFOviedo
Re: Allegiant
Post by GFOviedo »
According to RedFox the Redbox correct playlist is 838.
tindivall
Re: Allegiant
Post by tindivall »
GFOviedo wrote:According to RedFox the Redbox correct playlist is 838.
Mine is Netflix US and matches the 838 order as well.
Michael4824
Re: Allegiant
Post by Michael4824 »
For retail, I'm seeing 509, 511, 515, 501, 510, 503, 513, 502, 508, 504, 505, 507, 506, 512, 514, which is playlist 897. Can anyone confirm?
MustangChris04
Re: Allegiant
Post by MustangChris04 »
How are you able to watch this movie with PowerDVD? All I'm getting is a black screen, while other movies play fine with PowerDVD.
pd1215
Re: Allegiant
Post by pd1215 »
Redbox version is confirmed to be 838. Just watched the entire movie and it played correctly. Thanks to Axehandler for posting the mpls!!! :D
whkana
Re: Allegiant
Post by whkana »
I just rented the disc with Red Box, there is no 00838.mpls (the list goes from 00834 and jumps to 00840), and there is no Segment Map that starts with 513 - they all start with 518 instead. Please help!
whkana
Re: Allegiant
Post by whkana »
And if I go with Axehandler's post, then "File name: Allegiant_t254.mkv", then my version is the 00813, but the segment map totally does not match. Could someone please confirm?
