Allegiant
Re: Allegiant
Yes, does anyone know the correct mpls file for Redbox? I hate playlist obfuscation!
Re: Allegiant
Title information
Source file name: 00838.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,520,501,517,511,519,512,503,502,516,510,506,518,504,515,514,508,505,509,507
File name: Allegiant_t254.mkv
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Re: Allegiant
It's worse when you spend the money to buy it. I could use help with the BluRay/DVD/Digital HD US version. It would be much appreciated.
Re: Allegiant
Open MKV and look at the file list
ALL (or 95% of them) the Segment maps from MKV will begin with something (513 is the above example)
Open the folder to the STREAMS in the blu-ray.
Example : Allegiant\BDMV\STREAM
1) Now open the file 00513.m2ts and view the last 30 seconds or so...
2) Now go thru the other m2ts files to find the NEXT part of the video. (above was 520)
3) Now open the file 00520.m2ts and view the last 30 seconds or so... Repeat step 2...
I've found just knowing the 1st 3 segments (513,520,501) will generally give you only 1 file. MAYBE 2... that matches up in the MKV list.
feel free to repeat above steps till you match your file 100%.
BTW - to find this Segment, it took me about 3 mins.
Axe
Axe
Re: Allegiant
Netflix US version appears to be 209.mpls via powerdvd and proc monitor.
Title information
Source file name: 00209.mpls
Duration: 2:00:33
Chapters count:20
Segment count: 20
Segment map: 513,501,520,517,511,503,519,512,502,516,510,506,508,515,505,509,504,518,514,507
File name: Allegiant_t66.mkv
Can anyone else confirm this is correct?
Title information
Duration: 2:00:33
Chapters count:20
Segment count: 20
Re: Allegiant
If you watch those first three segments in order, it is wrong. 513, 520, 501 flows correctly.nick2421 wrote:Netflix US version appears to be 209.mpls via powerdvd and proc monitor.
513, sitting in chair at end.
520, sitting at chair at start, standing at end.
501, standing at start.
Re: Allegiant
bartman wrote:If you watch those first three segments in order, it is wrong. 513, 520, 501 flows correctly.nick2421 wrote:Netflix US version appears to be 209.mpls via powerdvd and proc monitor.
If 513, 520, 501 is indeed the correct starting order for the first 3 segments then only 1 fits, 838 as listed in the 3rd post by Axe
Re: Allegiant
According to RedFox the Redbox correct playlist is 838.
Re: Allegiant
Mine is Netflix US and matches the 838 order as well.GFOviedo wrote:According to RedFox the Redbox correct playlist is 838.
Re: Allegiant
For retail, I'm seeing 509, 511, 515, 501, 510, 503, 513, 502, 508, 504, 505, 507, 506, 512, 514, which is playlist 897. Can anyone confirm?
Re: Allegiant
How are you able to watch this movie with PowerDVD? All I'm getting is a black screen, while other movies play fine with PowerDVD.
Re: Allegiant
Redbox version is confirmed to be 838. Just watched the entire movie and it played correctly. Thanks to Axehandler for posting the mpls!!!
Re: Allegiant
I just rented the disc with Red Box, there is no 00838.mpls (the list goes from 00834 and jumps to 00840), and there is no Segment Map that starts with 513 - they all start with 518 instead. Please help!
Re: Allegiant
And if I go with Axehandler's post, then "File name: Allegiant_t254.mkv", then my version is the 00813, but the segment map totally does not match. Could someone please confirm?
