Is MakeMKV compatible with Windows 10?
Ant93
#1 Post by Ant93 » Mon Jul 11, 2016 1:02 pm
Title says it all, I'm thinking about upgrading to Windows 10 (64-bit Home edition) soon, shortly before the free upgrade offer ends, I just wanted to know whether MakeMKV works in Windows 10? Its just that Windows 10 is not mentioned in the system requirements on this page: /download/
Also, there hasn't been an update for MakeMKV since 17th April, is a new version due out soon?
Re: Is MakeMKV compatible with Windows 10?
#2 Post by Woodstock » Mon Jul 11, 2016 3:20 pm
Yes, MakeMKV runs on Windows 10, except that the default Windows 10 configuration MAY treat it like a virus and block execution. That will show up as a fatal error when you try to run it.
When Win10 came out, BitDefender would isolate one of the DLLs MakeMKV needs, probably because it contact the web server here to check for a newer version. That may be fixed now, because there have been few complaints about this over the last 5 months.
If you upgrade to Win10 and it does still fail, you can check out threads like this one: http://makemkv.com/forum2/viewtopic.php?f=1&t=10628
blufred
#3 Post by blufred » Mon Jul 11, 2016 6:45 pm
YUP works perfect in my WIN 10 64 bit
neilball
#4 Post by neilball » Tue Jul 12, 2016 11:47 am
No problems running with W10 64bit for me either.
whatever_gong82
#5 Post by whatever_gong82 » Wed Jul 13, 2016 7:49 am
I'm running Win 10 Pro, 64 bit, and MakeMKV is running excellently without any issue.
