hi
how do you open a iso in makemkv then i may make a backup to folders of the bdmv folders, the only way i could do it was to mount the iso in windows 10 then open makemkv or to would not see the iso?
also does makemkv need to connect to internet to a database to decrypt blu rays or does it do all its work offline?
and is it ok to run makemkv as a portable app as i opened setupmakemkv.exe using 7z and extracted to contents and ran the makemk.exe from there, or does it need to install dll's and stuff to the windows folder?
thx
