Deadpool Encoding Errors
kingofkongs
Post by kingofkongs »
I am rather new to MakeMKV and so far I have been really impressed. I did hit my first snag however as I have been trying to rip Deadpool and every time I have tried I get an error prior to completion. I have checked the disk and it appears to be without blemish and I also checked to see that I have the correct (I think) SVQ file loaded for the disk. Still no go. Here is the log:
Debug log started at Mon Jul  4 00:25:36 2016 , written by MakeMKV v1.9.10 darwin(x86-release)
001005:0000 MakeMKV v1.9.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /<path to home>/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW  GA32N KE06d" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BE14NU40 1.01d" opened in OS access mode.
DEBUG: Code 2147483648 at \@%sryo|/N:Wmp?4:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=ROXbJ1XEfokf2x4b+jdhHNpLycBMtESc4py2FIysXFADmE6KbELPZUqhGWrvpxOYF6wmpQlkCJMnc0PYb0aFHMfuauz5FnkaIKtjcQIyGxV2yrzucWdALkjc4PuuOwswQiLmSOYzz5f1+jt9uMHqw68wzMqbyaxFgA==
DCE=zSwZDOSt6oOxe2FId4CA6oQlZerwqmH7uBGB9Fq2twkQ+ktZEeKgaMR3rHabrOOEyQlNL3piURhzQkwbEA/uLe8hHoMF27nR/TsP24XTd2cW2ThHjjqpAaZ8GwJkkFUzONqJIlrW16PxgacwbIDaUWB0Azri5CRp3Q==
003317:0000 Loaded 530 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003322:0000 Processing BD+ code using disc-specific SVQ from /<path to Library>/MakeMKV/0000019b.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=CF6DEE6ECD2BE0F728A333A8586FCB3DD54F58D2
003025:0000 Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00250.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00356.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #0
003307:0000 File 00800.mpls was added as title #1
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00328.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00301.mpls was added as title #2
003025:0000 Title #00302.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00303.mpls was added as title #3
003307:0000 File 00304.mpls was added as title #4
003307:0000 File 00305.mpls was added as title #5
003025:0000 Title #00306.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.mpls has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00309.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00310.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00313.mpls was added as title #6
003307:0000 File 00318.mpls was added as title #7
003307:0000 File 00320.mpls was added as title #8
003307:0000 File 00321.mpls was added as title #9
003307:0000 File 00322.mpls was added as title #10
003307:0000 File 00335.mpls was added as title #11
003307:0000 File 00335.mpls(2) was added as title #12
003307:0000 File 00335.mpls(4) was added as title #13
003025:0000 Title #00336.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00340.mpls was added as title #14
003025:0000 Title #00341.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00344.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00347.mpls was added as title #15
003025:0000 Title #00348.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00349.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00351.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00352.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00353.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00354.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00801.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02451.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01927.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02559.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02450.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02608.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02636.m2ts was added as title #16
003025:0000 Title #02657.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02628.m2ts was added as title #17
003307:0000 File 02629.m2ts was added as title #18
003307:0000 File 02640.m2ts was added as title #19
003307:0000 File 02641.m2ts was added as title #20
003025:0000 Title #02646.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02647.m2ts was added as title #21
003307:0000 File 02648.m2ts was added as title #22
003307:0000 File 02659.m2ts was added as title #23
003025:0000 Title #02686.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02705.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02713.m2ts was added as title #24
003307:0000 File 02710.m2ts was added as title #25
003307:0000 File 02714.m2ts was added as title #26
005014:0000 Saving 1 titles into directory /Volumes/TB/MoviesTemp
001003:0020 DEBUG: Code 1073741829 at -Gpg`?<vV0 KoSW|:29393953
001003:0020 DEBUG: Code 100864261 at `-+6{6pNmTgC3Yr>:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02577.m2ts' at offset '2302279680'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk10' at offset '2302279680'
DEBUG: Code 1073741829 at N;87||f5zz=H&u>Wt_:213130904
001003:0020 DEBUG: Code 1073741829 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 100864261 at N;87||f5zz=H&u>Wt_:213130904
001003:0020 DEBUG: Code 100864261 at N;87||f5zz=H&u>Wt_:121262969
001003:0020 DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:121263291
001003:0020 DEBUG: Code 0 at :Etg}tshH7JYI{stw<}i:121262302
001003:0020 DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:213130812
001003:0020 DEBUG: Code 1124160 at =^M4rI33W2cx/\Cfg0*W:29393286
001003:0020 DEBUG: Code 0 at g/>>m:Vzl/$+*U=='upDy:29398967
001003:0020 DEBUG: Code 0 at 4J^(03;JK{JV]^A[f8w:213132767
RH2=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
FS ID=V_MPEG4/ISO/AVC C=1
TI=ZeNpjZGBgaFvnyIAOJkzdytAGpFnC7BkYGQgDmJoGdgYGCxYEfSCWgeElMwMDE0RaANksZgYBQRANAIEyCDg=
C_00000=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
001003:0020 DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:213131893
001003:0020 DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:121263406
001003:0020 DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:29393907
005003:0000 Failed to save title 1 to file /Volumes/TB/MoviesTemp/Deadpool_t01.mkv
005004:0080 0 titles saved, 1 failed
Anyone have any ideas?
Re: Deadpool Encoding Errors
Start with cleaning the disk. There is a problem that your drive can't read parts of it.
Is the LG drive plugged into a USB2 or USB3 port? If it's plugged into a USB2, it may not be getting sufficient power to operate at high speeds. Many drives will work fine on "just" USB2 power at low rotational speeds, but fail at higher speeds; the electronics shut down momentarily, causing the read to fail, and you will get several errors that indicate the drive is "off-line", then it returns.
Make sure it is plugged into a fully-powered USB3 port.
kingofkongs
Woodstock wrote:Start with cleaning the disk. There is a problem that your drive can't read parts of it.
This worked!
Not sure why because the drive is externally powered and shouldn't rely on drawing power from the USB port at all but when I switched the connection to a high powered USB3 port on a thunderbolt doc, the disk read fine. Thanks Woodstock!
