Drive Speed
mckbtr
Drive Speed
Post by mckbtr » Thu Apr 29, 2010 1:11 am
Have i missed something i cant seem to get MakeMkv to read @ full speed unless AnyDvd is runnig in the back ground
I only get a read speed of 3.4x max but if anydvd is open i get full 8x
mikeinessex
Re: Drive Speed
Post by mikeinessex » Thu Apr 29, 2010 8:38 am
does anydvd help makemkv work better? I have error issues on a few films and thinking maybe anydvd could help? Do you run anydvd before you rip or just have it running in the background?
skittle
Re: Drive Speed
Post by skittle » Thu Apr 29, 2010 3:59 pm
do not use anydvd+makemkv. makemkv does not need it and can cause issues.
mckbtr
Re: Drive Speed
Post by mckbtr » Fri Apr 30, 2010 1:29 am
i load anydvd but disable it just so i can get full speed rip
it would be nice if makemkv had a drive speed setting so i could dump anydvd all together
mikeinessex
Re: Drive Speed
Post by mikeinessex » Fri Apr 30, 2010 2:49 pm
does anyone know if it makes any difference to makemkv software if u put the serial key in or not?
NomadCF
Re: Drive Speed
Post by NomadCF » Fri Apr 30, 2010 8:56 pm
It does not.
Krobar
Re: Drive Speed
Post by Krobar » Sat May 01, 2010 9:57 am
mckbtr wrote:Have i missed something i cant seem to get MakeMkv to read @ full speed unless AnyDvd is runnig in the back ground
What drive make and model do you have?
NomadCF
Re: Drive Speed
Post by NomadCF » Sat May 01, 2010 7:34 pm
The discussion about how to reduce the file size, between my self and skittle. Was moved to
http://www.makemkv.com/forum2/viewtopic.php?f=6&t=1328
Due to fact that it really diverged too much from the "Drive Speed" question.
mckbtr
Re: Drive Speed
Post by mckbtr » Mon May 03, 2010 3:38 am
I am using a iHES208 that has been speed patched
here are some screen shots first is without Anydvd running
and the second is with Anydvd open but disabled and set to fast and noisy
i just wish i did not have to mess with anydvd at all
NomadCF
Re: Drive Speed
Post by NomadCF » Mon May 03, 2010 4:18 am
I have the iHES206, and see the same thing. Yet for me even with Anydvd(HD) I'm only seeing about 2.5x
UPDATE:
After some more testing I'm finding that nothing is reading from this drive at over 2.5X. So for me on this PC with this drive, it's got nothing to do with MakeMKV.
