The Expanse disc 1 will not open
torjhaug
#1 Post by torjhaug » Tue Jun 28, 2016 5:45 pm
makemkv will not open disc 1 in The Expanse season 1, disc 2 opens and rips ok.
The disc plays in a Blu-ray player.
Any suggestions?
Re: The Expanse disc 1 will not open
#2 Post by Woodstock » Tue Jun 28, 2016 6:03 pm
Follow the instructions in the FAQ link in my signature to turn on debug logging, and try the rip again.
Right now, without a log of what happened, the answer is, "don't know".
torjhaug
#3 Post by torjhaug » Tue Jun 28, 2016 6:19 pm
Thanks for quick response
Have sent mail with log, clpi files and mpls files
Looking forward to your response
#4 Post by Woodstock » Tue Jun 28, 2016 7:07 pm
Mail goes to Mike directly... If you could include the log in a reply, maybe the collective knowledge of "everyone except Mike" can come up with a reason, as well.
Don't bother trying to do it as an attachment - it probably won't work. Just copy and paste the text from the log in a reply.
torjhaug
#5 Post by torjhaug » Tue Jun 28, 2016 9:08 pm
Debug log started at Tue Jun 28 18:06:10 2016 , written by MakeMKV v1.9.10 win(x64-release)
001005:0000 MakeMKV v1.9.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\TorJH/MakeMKV_log.txt
DEBUG: Code 2147483648 at sOvXbpqt9^7}HS}M:121265315
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=lBg+/9AM/dsMpIj2C+phvUwzREXpHhYK99YO7JkfBFr7X2Zoz1f1XZXT3IVXRRRzTF6MRL/WVZrpeP0b0PaZzc4MBJpb9pgwe8N2qxUyQT5j325YF+yb4JwpNF+H0DQrSV90771q32kZ+fdDAn54ENoP1Ln8t5GHaQ==
DCE=8b1PXlKpcsOn5CtEUl5GYylAWeT8n+mWYbqkbrn9PuoqFTJoWxloJjuf2JCNZCHyDqJZvBwIzuE4UBX+y0sdfWNXNQIIcjq3APU5ZLGuB7B+8xG3p0m1EttTBnJLfbDGQvjXMqM9CK1PhIwr05tdVCrkJssaFQLg0Q==
DISCID=93CCCAE799609A073DE63BEC57DC2581F8CB8320
003025:0000 Title #00800.mpls has length of 2686 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00052.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00053.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00055.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00070.mpls has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00074.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00075.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00801.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00802.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00803.mpls has length of 2554 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00804.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 9 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 2686 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 132 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 62 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50424.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50425.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50426.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50427.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50428.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50429.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50430.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50431.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50432.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50434.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50435.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50437.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50438.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50439.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50440.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50446.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50447.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50448.m2ts has length of 2554 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50449.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50450.m2ts has length of 31 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50451.m2ts has length of 58 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50452.m2ts has length of 17 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Application exited at Tue Jun 28 18:11:40 2016
#6 Post by Woodstock » Tue Jun 28, 2016 9:11 pm
If this is an "Extras" disk, it is quite possible that the 1 hour minimum you've put on titles is making it impossible for MakeMKV to find anything to rip. What happens if you shorten the minimum to, say, 120 seconds?
torjhaug
#7 Post by torjhaug » Wed Jun 29, 2016 2:23 pm
Thanks for the advice, it worked out.
I got confused by the "Failed to open disc".
I have ripped more than 500 Blu-rays recently and have used 3600 seconds to find the movie as easy as possible.
I rip the movie only with the best audio quality and english subtitles, no menus or extras.
For multi episode TV series discs I will have to use e.g. 120 seconds.
I had the same error ("Failed to open disc") with the Battlestar Galactica discs, I am sure they will rip OK now.
Again, thanks for the excellent advice.
