makemkv will not open disc 1 in The Expanse season 1, disc 2 opens and rips ok.
The disc plays in a Blu-ray player.
Any suggestions?
The Expanse disc 1 will not open
Re: The Expanse disc 1 will not open
Follow the instructions in the FAQ link in my signature to turn on debug logging, and try the rip again.
Right now, without a log of what happened, the answer is, "don't know".
torjhaug
Thanks for quick response
Have sent mail with log, clpi files and mpls files
Looking forward to your response
Mail goes to Mike directly... If you could include the log in a reply, maybe the collective knowledge of "everyone except Mike" can come up with a reason, as well.
Don't bother trying to do it as an attachment - it probably won't work. Just copy and paste the text from the log in a reply.
torjhaug
Debug log started at Tue Jun 28 18:06:10 2016 , written by MakeMKV v1.9.10 win(x64-release)
001005:0000 MakeMKV v1.9.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\TorJH/MakeMKV_log.txt
DEBUG: Code 2147483648 at sOvXbpqt9^7}HS}M:121265315
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=lBg+/9AM/dsMpIj2C+phvUwzREXpHhYK99YO7JkfBFr7X2Zoz1f1XZXT3IVXRRRzTF6MRL/WVZrpeP0b0PaZzc4MBJpb9pgwe8N2qxUyQT5j325YF+yb4JwpNF+H0DQrSV90771q32kZ+fdDAn54ENoP1Ln8t5GHaQ==
DCE=8b1PXlKpcsOn5CtEUl5GYylAWeT8n+mWYbqkbrn9PuoqFTJoWxloJjuf2JCNZCHyDqJZvBwIzuE4UBX+y0sdfWNXNQIIcjq3APU5ZLGuB7B+8xG3p0m1EttTBnJLfbDGQvjXMqM9CK1PhIwr05tdVCrkJssaFQLg0Q==
DISCID=93CCCAE799609A073DE63BEC57DC2581F8CB8320
003025:0000 Title #00800.mpls has length of 2686 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00052.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00053.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00055.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00070.mpls has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00074.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00075.mpls has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00801.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00802.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00803.mpls has length of 2554 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00804.mpls has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 9 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 2686 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 132 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 62 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 29 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 60 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50424.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50425.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50426.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50427.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50428.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50429.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50430.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50431.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50432.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50434.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50435.m2ts has length of 15 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50437.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50438.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50439.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50440.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50446.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50447.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50448.m2ts has length of 2554 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50449.m2ts has length of 2585 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50450.m2ts has length of 31 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50451.m2ts has length of 58 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #50452.m2ts has length of 17 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Application exited at Tue Jun 28 18:11:40 2016
If this is an "Extras" disk, it is quite possible that the 1 hour minimum you've put on titles is making it impossible for MakeMKV to find anything to rip. What happens if you shorten the minimum to, say, 120 seconds?
torjhaug
Thanks for the advice, it worked out.
I got confused by the "Failed to open disc".
I have ripped more than 500 Blu-rays recently and have used 3600 seconds to find the movie as easy as possible.
I rip the movie only with the best audio quality and english subtitles, no menus or extras.
For multi episode TV series discs I will have to use e.g. 120 seconds.
I had the same error ("Failed to open disc") with the Battlestar Galactica discs, I am sure they will rip OK now.
Again, thanks for the excellent advice.
