Drive Speed
Drive Speed
Have i missed something i cant seem to get MakeMkv to read @ full speed unless AnyDvd is runnig in the back ground
I only get a read speed of 3.4x max but if anydvd is open i get full 8x
mikeinessex
Re: Drive Speed
does anydvd help makemkv work better? I have error issues on a few films and thinking maybe anydvd could help? Do you run anydvd before you rip or just have it running in the background?
Re: Drive Speed
do not use anydvd+makemkv. makemkv does not need it and can cause issues.
Re: Drive Speed
i load anydvd but disable it just so i can get full speed rip
it would be nice if makemkv had a drive speed setting so i could dump anydvd all together
mikeinessex
Re: Drive Speed
does anyone know if it makes any difference to makemkv software if u put the serial key in or not?
Re: Drive Speed
What drive make and model do you have?mckbtr wrote:Have i missed something i cant seem to get MakeMkv to read @ full speed unless AnyDvd is runnig in the back ground
Re: Drive Speed
The discussion about how to reduce the file size, between my self and skittle. Was moved to
http://www.makemkv.com/forum2/viewtopic.php?f=6&t=1328
Due to fact that it really diverged too much from the "Drive Speed" question.
Re: Drive Speed
I am using a iHES208 that has been speed patched
here are some screen shots first is without Anydvd running
and the second is with Anydvd open but disabled and set to fast and noisy
i just wish i did not have to mess with anydvd at all
Re: Drive Speed
I have the iHES206, and see the same thing. Yet for me even with Anydvd(HD) I'm only seeing about 2.5x
UPDATE:
After some more testing I'm finding that nothing is reading from this drive at over 2.5X. So for me on this PC with this drive, it's got nothing to do with MakeMKV.
UPDATE:
