ST-TNG S1 Disc 3
Blu-Brother
ST-TNG S1 Disc 3
Post by Blu-Brother »
Title 3 of this disc will not copy. I've gotten the other 4 files off except this one. Here is the error code:
Saving 1 titles into directory /Volumes/NTSC/STTNG
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3645831168'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3645831168'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3695572992'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3697145856'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3715104768'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3715104768'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3716677632'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3716677632'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3720148992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3720148992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3720151040'
Failed to save title 3 to file /Volumes/NTSC/STTNG/title03.mkv
0 titles saved, 1 failed
Re: ST-TNG S1 Disc 3
Your drive is having problems reading the disk. Since most of the errors seem to "fix" themselves after a retry (the locations keep advancing), it is likely cleaning the disk will fix the issue.
preserve
Post by preserve »
Just a suggestion because it seems there are a lot of threads with this issue (I'm pretty sure I posted one myself the first time I ran into this) - a sticky thread titled something along the lines of "READ FIRST if you get SCSI / Medium errors"
Using: ASUS BW-16D1HT 3.00
Blu-Brother
Thanks! That worked. Didn't think it needed cleaning especially since it was brand new.
"Brand new" means nothing. I've had disks come in with big fingerprint smears on them, and subtle reflections that looked like suction cup marks on the data side.
