ST-TNG S1 Disc 3
Blu-Brother
ST-TNG S1 Disc 3
Post by Blu-Brother » Wed Jun 22, 2016 2:11 pm
Title 3 of this disc will not copy. I've gotten the other 4 files off except this one. Here is the error code:
Saving 1 titles into directory /Volumes/NTSC/STTNG
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3645831168'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3645831168'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3695572992'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3697145856'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3715104768'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3715104768'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3716677632'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3716677632'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '3720148992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3720148992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '3720151040'
Failed to save title 3 to file /Volumes/NTSC/STTNG/title03.mkv
0 titles saved, 1 failed
Re: ST-TNG S1 Disc 3
Post by Woodstock » Wed Jun 22, 2016 3:17 pm
Your drive is having problems reading the disk. Since most of the errors seem to "fix" themselves after a retry (the locations keep advancing), it is likely cleaning the disk will fix the issue.
preserve
Post by preserve » Thu Jun 23, 2016 3:06 am
Just a suggestion because it seems there are a lot of threads with this issue (I'm pretty sure I posted one myself the first time I ran into this) - a sticky thread titled something along the lines of "READ FIRST if you get SCSI / Medium errors"
Using: ASUS BW-16D1HT 3.00
Blu-Brother
Post by Blu-Brother » Fri Jun 24, 2016 2:55 pm
Thanks! That worked. Didn't think it needed cleaning especially since it was brand new.
Post by Woodstock » Fri Jun 24, 2016 6:04 pm
"Brand new" means nothing. I've had disks come in with big fingerprint smears on them, and subtle reflections that looked like suction cup marks on the data side.
