MakeMKV - My AnyDVD Replacement
PCTools
#1 Post by PCTools » Mon Jun 20, 2016 2:29 am
Here is what I want to do:
1) Use MakeMKV to convert my Blu-Ray Media to MKV's.
2) When I want to create a duplicate Blu-Ray from an MKV, I need to determine the best method to perform this task.
If the file is less than 25GB, I will not need to use BD-Rebuilder, if larger I can use to reduce the file size to a BD25 structure.
I just tried this process, of taking a 31GB MKV file, using BD-Rebuilder to reduce and then process with IMGBurner.
- The bad news, I am doing something wrong and do not understand the process.
- My DVD player tells me the format is not supported, and will not play.
- When I play the disc on my computer using VLC, I can see the picture but no sound.
I installed BD-Rebuilder per http://forum.doom9.org/ and was not successful.
- I have performed this in the past, but never tried to change a MKV to a BD format, which is where I think I am going wrong.
Any feedback would be great.
Thank you!
JasonSGN
Re: MakeMKV - My AnyDVD Replacement
#2 Post by JasonSGN » Wed Jun 22, 2016 1:44 am
It's not free, but ConvertXtoVideo (http://www.vso-software.fr/products/vid ... -video.php) would do exactly what you'd want. I've been using it for almost a year and it works nicely and is constantly updated.
#3 Post by Woodstock » Wed Jun 22, 2016 3:34 am
I don't see how a converter program is going to correct the problem the OP is having with his/her drive not being able to switch layers...
A single-layer BD is 25GB, and, like dual-layer DVDs, going beyond that requires that the laser refocus onto a different layer. If 25GB works, but 26GB fails, it is usually a disk or drive issue. Some older BD writers are limited to single-layer writing, but will read up to 4 layers.
PCTools
#4 Post by PCTools » Wed Jun 22, 2016 10:16 am
I think you misunderstood the question.
It is more of a question on the easiest method to take an MKV and proceed to a Blu-Ray file format playable of your stand-alone player. (With maintaining DTS-HD Master)
Woodstock wrote:I don't see how a converter program is going to correct the problem the OP is having with his/her drive not being able to switch layers...
yorgo
#5 Post by yorgo » Wed Jun 22, 2016 10:47 am
PCTools wrote: It is more of a question on the easiest method to take an MKV and proceed to a Blu-Ray file format playable of your stand-alone player. (With maintaining DTS-HD Master)
I've never had the need to do what you're looking for but, on rare occasions, I use TSMuxer (http://www.videohelp.com/software/tsMuxeR) to create ISO's from BDs but the software can also take an MKV and remux to BD folder structure. Just tested on a MKV file, seems to work fine. I did not burn to a disc nor have the means to test this feature. Also, TSMuxer does not reduce file size on the fly and convert at the same time, ie <25G MKV to >25G BD folder. Hope this helps.
JasonSGN
#6 Post by JasonSGN » Wed Jun 22, 2016 12:21 pm
The OP is looking for a program that will convert an MKV file greater than 25GB to a single-layer BD structure. The program I mentioned will do exactly that.
PCTools
#7 Post by PCTools » Thu Jun 23, 2016 9:29 am
This is exactly what I was looking for...
Thank you!
http://www.vso-software.fr/shop.php
They have so many products. I wonder if I am better of getting ConverXtoHD.
http://www.vso-software.fr/products/convert-x-to-hd/
JasonSGN wrote:It's not free, but ConvertXtoVideo (http://www.vso-software.fr/products/vid ... -video.php) would do exactly what you'd want. I've been using it for almost a year and it works nicely and is constantly updated.
PCTools
#8 Post by PCTools » Thu Jun 23, 2016 9:31 am
I have no issues with a BD25 or BD50.
I was looking for a program which would convert MKV to BD structure without having any loss.
I think I found the solution with with the above mentioned software.
