macOS Sierra & makeMKV 1.9.10
cjc1959au
Post by cjc1959au » Fri Jun 17, 2016 4:58 am
Hi Guys,
Just an update for you. Mostly, makeMKV & macOS Sierra appear to work well together.
Usually, the only things I change in preferences are:
Minimum Title Length
Default Destination
Minimum Title Length I can change without a problem. Currently it's set at 199.
Default Destination always crashes makeMKV.
Auto seems to work OK and is obviously the default.
SemiAuto seems to work OK, and doesn't crash makeMKV.
Custom will open the browse window, but as soon as I try to select a folder, makeMKV crashes big time.
Currently, I've left makeMKV on SemiAuto and it seems to be ripping without any real problems.
Yes, I have daspi installed.
Hoping this can be fixed, although as Sierra has only just come out as a Developer Preview, maybe not yet.
Love the software and have a license!
Christopher
PS . It won't let me upload the error message as either a txt file or a ZIP, but I have it if it will assist anyone.
Re: macOS Sierra & makeMKV 1.9.10
Post by Woodstock » Fri Jun 17, 2016 2:07 pm
Destination directory can be a pain at times, but it should not crash the program. If you can locate the OS X crash report for when it happens, I think Mike would appreciate you sending a copy of it to support@makemkv.com so that he can check into it.
cjc1959au
Post by cjc1959au » Sat Jun 18, 2016 10:06 am
Done!
