Married with Children error
dlingen
#1 Post by dlingen » Fri Jun 17, 2016 1:05 am
I've used makemkv for some time. I have a license and am running v1.9.10 on Win 7 Pro. Works well however I've run into a problem dubbing Married with Children Season 7 discs 2 and 3. Disc 1 was fine. Disc's are new virgin. The error is:
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE BH16NS40 1.03' at offset '1048576'
Before posting this I did a search on Married with Children. No results so I started this new topic. I've purchased and moved to PLEX all the shows without issue except for these two discs. Any help would be appreciated.
Thank you.
Re: Married with Children error
#2 Post by Woodstock » Fri Jun 17, 2016 3:38 am
What happened after the error popped up? I see that error every 5-10 disks when dealing with DVDs, and MakeMKV has always worked around it. But sometimes... it can be a problem with some drives.
dlingen
#3 Post by dlingen » Fri Jun 17, 2016 5:03 pm
Thanks Woodstock. It didn't occur to me to continue after the error message. I continued and all worked out fine.
