Anomalisa
thirstyspider
Anomalisa
Post by thirstyspider » Fri Jun 17, 2016 12:58 am
Trying to rip Anomolisa blu-ray and I get an error, apparently due to AACS v61
Running Mac OS 10.11.5 and licensed copy of MakeMKV 1.9.10
Do I need to wait on an update to MakeMKV? This is the first disc I have had trouble with and I've had the program for awhile. Thanks for any help/guidance. I'm reading what I can.
OS device name: /dev/rdisk3
Manufacturer: hp
Product: DVDWBD TS-LB23L
Revision: 0500
Serial number: R4226GOB102101
Highest AACS version: 61
Disc Information
Label: Anomalisa
Timestamp: 2016-03-02 14:55:25
Data capacity: 36.12 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
Re: Anomalisa
Post by Woodstock » Fri Jun 17, 2016 3:36 am
What, specifically, were the errors? Can you process ANY Blurays, or are you now limited to DVD by the drive?
A new version of AACS does not necessarily mean that MakeMKV has to be updated, it is ONLY necessary if the key MakeMKV uses is included in the lock-out list. Sometimes it survives for 2 or 3 revisions. :)
There should be a file in your MakeMKV data directory with a name that starts with "MKV_v61"; if the problem is AACS, there should have been a message in the log screen to send that file to svq@makemkv.com for analysis. Please forward it so that Mike can upgrade the AACS level in MakeMKV, if needed.
thirstyspider
Re: Anomalisa
Post by thirstyspider » Fri Jun 17, 2016 4:01 am
I'll get back in tomorrow night and enable logging and get those files emailed. The drive otherwise works fine. I have a similar drive at work and received the same errors from the same disc.
Thanks for your help.
Re: Anomalisa
Post by Woodstock » Fri Jun 17, 2016 2:02 pm
OK, if you still can read BDs, AACS v61 isn't the issue, but I'm sure Mike would appreciate having a copy of the file in any case.
