So I am getting the error codes when I rip blu rays, as I have tried multiple different ones and the same error code string is coming up.
Saving 1 titles into directory K:/New Movies 6.14.16-
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19139063808'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146209280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19146215424'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146215424'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146215424'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146209280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19146221568'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Failed to save title 1 to file K:/New Movies 6.14.16-/The_Hobbit_The_Desolation_of_Smaug_t01.mkv
Problem Saving Blu-ray Conversion
Re: Problem Saving Blu-ray Conversion
Your computer is saying that the drive isn't ready, and is having read issues. First thing to try is a hard reset, as in power-down-and-restart, to make sure both the drive and the motherboard reconnect.
DJMCFog
I have reset my computer multiple times already but it did not work. I have already made rips of dvds, it is specifically blu rays which are not working. Any help would be great.
Without more information it will be hard to say what would fix it. You're saying that ALL BDs fail, or just "most"? No errors with DVDs?
Does it read well for about 15-20GB, then start failing? It is possible that the laser isn't able to refocus for reading more than the base layer on BDs.
