Problem Saving Blu-ray Conversion
DJMCFog
Post by DJMCFog » Wed Jun 15, 2016 12:25 pm
So I am getting the error codes when I rip blu rays, as I have tried multiple different ones and the same error code string is coming up.
Saving 1 titles into directory K:/New Movies 6.14.16-
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19139063808'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146209280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19146215424'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146215424'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146215424'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146209280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19146221568'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19146221568'
Failed to save title 1 to file K:/New Movies 6.14.16-/The_Hobbit_The_Desolation_of_Smaug_t01.mkv
Re: Problem Saving Blu-ray Conversion
Post by Woodstock » Wed Jun 15, 2016 7:03 pm
Your computer is saying that the drive isn't ready, and is having read issues. First thing to try is a hard reset, as in power-down-and-restart, to make sure both the drive and the motherboard reconnect.
DJMCFog
Post by DJMCFog » Wed Jun 15, 2016 11:50 pm
I have reset my computer multiple times already but it did not work. I have already made rips of dvds, it is specifically blu rays which are not working. Any help would be great.
Post by Woodstock » Thu Jun 16, 2016 4:54 am
Without more information it will be hard to say what would fix it. You're saying that ALL BDs fail, or just "most"? No errors with DVDs?
Does it read well for about 15-20GB, then start failing? It is possible that the laser isn't able to refocus for reading more than the base layer on BDs.
