Problems with Game of Thrones Blu-rays
schmadrian
Post by schmadrian »
Recently, while backing up my library, I'm finding that, in many instances, I am unable to convert the episodes. I can do the bonus features, but not the episodes. I'm not sure of the protocols regarding showing the error messages, but I'll cut-and-paste them here:
MakeMKV v1.9.10 darwin(x86-release) started
Optical drive "BD-RE MATSHITA BD-MLT UJ265 1.00d" opened in OS access mode.
Evaluation version, 26 day(s) out of 30 remaining
File 00802.mpls was added as title #0
Title #00007.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.mpls was added as title #1
File 00803.mpls was added as title #2
Title #00055.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00053.mpls was added as title #3
File 00020.mpls was added as title #4
File 00002.m2ts was added as title #5
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00071.m2ts was added as title #6
Title #00072.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00082.m2ts' at offset '3600384'
Failed to decode audio/video data for title #7 - invalid mux or internal error, title skipped.
Title #00082.m2ts was skipped
Title #00083.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00085.m2ts was added as title #7
Title #00086.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00091.m2ts' at offset '589824'
Failed to decode audio/video data for title #8 - invalid mux or internal error, title skipped.
Title #00091.m2ts was skipped
Title #00092.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00101.m2ts was added as title #8
File 00106.m2ts was added as title #9
File 00108.m2ts was added as title #10
File 00109.m2ts was added as title #11
File 00111.m2ts was added as title #12
File 00112.m2ts was added as title #13
File 00113.m2ts was added as title #14
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00256.m2ts was added as title #15
File 00258.m2ts was added as title #16
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00260.m2ts' at offset '61440'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00260.m2ts' at offset '61440'
Failed to decode audio/video data for title #17 - invalid mux or internal error, title skipped.
Title #00260.m2ts was skipped
File 00265.m2ts was added as title #17
Title #00022.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 18 titles into directory /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '629403648'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '629403648'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '629407744'
Failed to save title 0 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t00.mkv
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00071.m2ts' at offset '956166144'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '956166144'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '956170240'
Failed to save title 2 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t02.mkv
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00067.m2ts' at offset '0'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '0'
Failed to save title 4 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t04.mkv
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '532611072'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '532611072'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '532611072'
Failed to save title 5 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t05.mkv
Failed to save title 6 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t06.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Forced subtitles track #13 turned out to be empty and was removed from output file
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00109.m2ts' at offset '378273792'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '378273792'
Failed to save title 11 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t11.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00258.m2ts' at offset '106622976'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '106622976'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '106627072'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00258.m2ts' at offset '106622976'
Failed to save title 16 to file /Volumes/Numenor/To Be Handbraked/Game of Thrones Season 2/Game_Of_Thrones_Season_2_Disc_2_t16.mkv
11 titles saved, 7 failed
Any insight keenly appreciated.
Re: Problems with Game of Thrones Blu-rays
Errors like "Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00091.m2ts' at offset '589824'" and "Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00260.m2ts' at offset '61440'" indicate that the drive is not able to read portions of the disk, and is getting confused about where the data is. Read errors can be as simple as a dirty disk, or problems with the drive itself.
